AULTD
Can anyone tell me if I bridge terminals 30 and 87 where the starter relay plugs in should the starter motor crank? This is on an AUII V8.
I have checked that there is 12V coming from terminal 30 but when I plug the wire into 87 nothing happens. Does the key have to be on? I am trying to track down a starting problem ( see other thread ) |
Smile
Go buy a spare relay.Unplug each one at a time and see if the car starts
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
AULTD
I have swapped the relays and no difference.
The manual tells me to bridge terminals 30 and 87 which takes the relay out of the equation. What I want to know if someone else can bridge these terminals and see if the starter motor cranks over. Try it with the key off and key on. The manual is a bit vague. |
AULTD
I put a multimeter on the small wire that goes to the starter motor and with the terminals mentioned above bridged the power is reaching the solenoid.
I also checked the large 12V supply from the battery and it is also getting to the starter motor. It is pointing towards the solenoid being faulty. I know you can bridge the terminals on the back of the starter motor with a screwdriver but I don't want to be under the car with it trying to start. |
