#31 | |||
Now Fordless
Also with that engine the timing covers corrode out. Laser b6 - Crank keyway wearing. Mitsubishi 4m40 - Head cracks Kia Carnival v6 - Head gaskets |
#32 | ||
Holden injected V8 allways sludged up in the pickup and making not much if any oil pressure :p apart from that pretty flawless really bottom ends good for limited usage at 8000 rpm stock or 350 rwkw boosted is ok on stocker, good motors. Never seen one fail, ever over a period of about 100 5 minute burnouts between 5500 and 7500 rpm
Holden early V6, falls apart at over 6,000 rpm pretty easy, broken cam, or rod failure. Seen more of these break in burnout comps than any other motor, but like most things can make bulk power boosted so long as you keep them under 5500. RB30 fall apart at 7000 rpm+, otherwise can hold 300rwkw+ stock they just dont want to see North of 7000rpm. They break fail often at high rpm Ford 6, various headgasket issues also overheats during long burnouts and can lock up but never seen one fail, they allways come good once cooled down, have to add that any Fords are quite rare to see in competitions of any kind but still, never seen one fail Holden 6 much stronger than you would expect especaily the blue motors, have seen stock bottom ends with 20 psi. Haven't seen one fail in a burnout comp but they are usually worn out old bombs that cant do more than 4000 rpm in 2nd ![]() |
#33 | ||
Mazda/Ford KL/KF/K8 (2.5,2.0 and 1.8) V6 engines- have problems with the friction operated anti-backlash camshaft drive. Not a huge problem but is a substantial cost to replace, especially with how crammed in the engines are.
#34 | ||||
AFF's 1st DM.......
#35 | ||
XF 393 3v CHI heads
a holden v8 threw a rod at the burnouts on friday, the bottom ends dont die often because the valvetrain fails before the rods get a chance...oh and the fact that MOST injected holden motors in burnout cars rarely make more then 400hp....
XF Falcon, 393 Clevo. 11.01@123mph "RAZNREVNU" |
#36 | |||
Weezland
#37 | |||
![]() It ran 8500 rpm the motor was fine at the end despite the flamage:P Last edited by greenfoam; 20-04-2009 at 03:59 AM. |
#38 | ||
moonlight rider
I must have very good luck as i have owned 3 ea falcons and 1 fairmont,my sister had a fairmont 89 model and we never had this head gasket problem.For example my current falcon(3.9 manual 91) i bought when it was sitting on 230,000 kms and now im up to 433,000 kms and have had no issues with mine at all,my sisters fairmont was bought at 62,000 kms and was driven every day up until 340,000 odd kms and like mine it was never touched by a mechanic,all servicing was done privately and oil and water checked regularly.For the price i am going to find it very very hard to stray away from the ea-ed series as they are so basic to change parts over and can be made to look very good when done right.
#39 | |||
Force Fed Fords
LS1 had an alloy block, which just amplified the piston slap. The problem was that GM, in order to remove a substantial amount of reciprocating mass, decided to hollow out most of the piston skirt to form a piston that looked basically like a big letter I. This meant that under normal conditions (let alone high RPM) the pistons had a tendency to twist under the load of ignition, eventually wearing the lower end of the piston and the cylinder it travelled in creating an even louder slapping noise. GM tried to cover it up with advice that it was normal, but several class actions and a couple million motors later and GM finally decided to redesign the pistons. There are class actions still ongoing, in my case a WH caprice that I bought had 3 motors in 40,000klm, a paid engineer and a court case and eventually I received a refund.
More details http://www.pistonslap.com/photos.htm
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley Quote:
