Old 27-10-2009, 01:44 PM   #1
4dlvr
4dlvr
Default lr zetec problem
i own a 04 zetec, 55000km manual
i haven't driven my focus for almost a year now, so i changed the oil and battery before i first started it, at first it was ok but now i think theres a few problems..
1)the car lacks power when under load between 3000-6000rpm, it almost in slow motion for abit, while this happens there is a unhealthy ringing sound coming from the motor..
2)also if im under 2000rpm the car makes the same noise as if i put foot flat to the floor in third gear at 5km/h..
3)also theres alot of squeezing and annoying noises when possibly from the diff..
i think 1 might be sparkplugs possibly???
2 im thinking is clutch
and 3 new diff oil maybe???
this car is just very new and very well taken care of
any suggestions??
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 02:30 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
When you say you haven't driven it for a year, does that mean it was just sitting in a shed, or someone else was driving during that time?
Apart from taking it to a service centre (probably your best bet....really ) I'd change filter and plugs, plus check that the spark plug wires and timing belts aren't perished (I'd probably change wires as well really), or check that something hasn't crawled up and died in the engine bay! (Stranger things have happened!!!!)
Check the engine oil to see that it's not milky, and check the water as well
It sounds to me like a dead cat converter, but I can't see how not driving it for a year would cause that (rust and corrosion???)
Are is something else rusted?
Hopefully someone is more help that me
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 03:50 PM   #3
FORD5
FORD5's Avatar
Ahh i agree melb, i'd say it sitting for 12 months something has perished, was there fuel left in the fuel tank, and did you change fuel filter inner and outter one? worth a try
FORD5 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 04:19 PM   #4
melbzetec
melbzetec's Avatar
Good point on the fuel! Hadn't thought of that.
Fuel will deteriorate over time, perhaps sediment, perhaps water, perhaps the injectors gummed up
New fuel filter, full tank of premium, with a bottle of Caltex Techron, and then an Italian tune up along the freeway (ie drive the thing HARD).
..........I'd still go to a service centre.......
p.s. I just noticed. Over 2000 posts from me!
I'm sure some of them made sense!
Old 27-10-2009, 05:22 PM   #5
4dlvr
4dlvr
it had been sitting in the garage for 12 months.
oil is new, no milkiness, no signs of a bad head gasket..
spark plugs and ignition leads will be changed soon but i doubt its them..
it really sounds like something in the motor is loose..
the fuel inside is new, cat seems fine, its still shiny,
ill drive it again and see if i notice anything, im starting to get a slight feeling that when it laggs under load its almost as if its its missing or 1 cylinder is not working
96 EF FAIRMONT
215rwkw @7psi
Old 27-10-2009, 10:51 PM   #6
FORD5
FORD5's Avatar
Yep best to probally drain the fuel, change filters, fill her up with 98RON, perhaps try some injector cleaner through it?
Old 27-10-2009, 10:53 PM   #7
FORD5
FORD5's Avatar
Hmmmm If it hesitates or laggs under load, and or has a slight miss, i'd be pointing toward plugs and leads
Edit: A/C's should be ran regardless every 2 weeks, to prevent seals drying out, and HIMS in the heater seizing, btw HIMS cost near 1k for a fix and whole dash has to be removed (5-6 hour job) from memory, so try your climate control/A/C
Old 27-10-2009, 11:05 PM   #8
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
While you're rummaging around under the bonnet check your MAF plug (should be the only one in the airbox) and maybe even pull the air filter out and give it a once over. Then check that all the plumbing in the intake system is intact and properly sealed and all clamps done up.
The problems you described could also be a mixture problem (confused MAF)
On the topic of plugs and leads however, I remember my LR got some water down in the valley between the cams. I don't think the plug tops sealed properly. Anyway I found that it was making it miss fire, probably shorting the lead against the head. I popped the leads out, blasted it with the air hose (with the plugs still IN, that's important!) and it was fine after that. Needed new leads eventually but it cleared it up.
It could be a multitude of things, we're all just brainstorming here.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!!
1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2009, 09:07 AM   #9
FORD5
FORD5's Avatar
Yer i agree, I'd just go over it and check it out, if it's still playing up and you cant find a prob (yourself) find a mechanic. cheers
Old 28-10-2009, 06:37 PM   #10
Dustproof
Dustproof's Avatar
Default Problems
any suggestions??
Yeah for sure, Empty the fuel from the tank and fill it with new stuff. The engine will ping and rattle because it is not running properly, it is nothing loose. I have had this problem with bikes I have restored, same noises etc. Don't bother adding new fuel to the old because it won't work, you can get an additive to revive old fuel but after finding out why fuel goes stale I would think it is a waist of money.
Step one, empty the Tank.
Step two, drain all the fuel lines.
Step three, replace the fuel filter.
Step four, refill the tank with clean fuel.
Step five, take it for a drive and see how it goes.
If it still has problems, check the spark plugs because they can get carbon all over them and foul with unburnt fuel - replace them. If you still have problems, get some fuel injection cleaner and pour it in the tank. Drive it again and you shouldn't have problems.
Rule of thumb, if not driving the car for an extended period, empty the fuel tank. Pull the plugs and give it a spray with WD40 and reinstall the plugs, after that disconnect the battery or get a battery tender to condition the battery whilst your away.
I hope this helps.
Noel
1400 GTR Goes like it has a Kwaka up its butt
Dustproof is offline   Reply With Quote Multi-Quote with this Post
