Old 03-12-2009, 04:59 PM   #1
wkd-windza
wkd-windza's Avatar
Default ZEX perimiter nitrous plate
Im replacing my NOS big shot plate with a ZEX perimiter plate, i know NOS brand jets arent suitable but need to know will the ZeX jets fit into the -6 lines that are supplied with the NOS big shot kit??
Tyres are evil and must be punished
wkd-windza is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2009, 06:21 PM   #2
FLUB378
Don't the jets sit inside an A/N fitting? Nothing goes in the line itself. It depends what size line is run with the zex kit. If it is a dash 4 line then use a speedflow Dash 6 to Dash 4 reducer. If the zex plate uses A/N fittings then yes the Dash 6 line will fit somehow.
FLUB378 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2009, 02:27 AM   #3
wkd-windza
wkd-windza's Avatar
Im worried about the ZEX jets not being compatible with the an fitting, ive heard they are dimensionally different from the NOS brand jets but not sure if they mean flow wise or outside dia. wise
Old 05-12-2009, 09:22 AM   #4
FLUB378
You would assume that they mean flow rate as all nitrous kits are built with commercially available A/N fittings used. All commercially available A/N fittings are interchangable with the same threads and I/D's used. The O/D's, external appearance and the internal flow characteristics are the only variances better different brands of fittings
Old 05-12-2009, 12:33 PM   #5
wkd-windza
wkd-windza's Avatar
Found this at Summit
"If converting your NOS® or Edelbrock® plate system to the
ZEX™ Perimeter Plate, you will need to purchase ZEX™ compatible jets in the sizes that NOS® and Edelbrock® recommend for the plate you are replacing."
Old 06-12-2009, 06:11 PM   #6
FLUB378
Thats a good result. You only have to buy different jets
Old 06-12-2009, 08:09 PM   #7
wkd-windza
wkd-windza's Avatar
Perhaps, but can only find ZEX jets up to a 175 shot
Old 08-12-2009, 12:25 PM   #8
Mr. CVE
If it aint Blown it Sucks
Mr. CVE's Avatar
leave em out then !!
That will give you more !
perhaps the plate can't flow more than 175, or the solenoids etc
don't forget the plate also has to flow the fuel as well.
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph
@235 rwkw !!
Now turbo 11.77 @114 mph
320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds:
Now for sale
http://www.fordforums.com.au/showthread.php?t=11296772
Thanks to Snort Performance, Headsex and CVE
Street car DeTomaso Pantera
Drag car 1995 Mustang, Haleys Comet ( It's back !)
Power by CVE
Melbourne's first SNIPER Tuner :
Now tuning E series
Mr. CVE is offline   Reply With Quote Multi-Quote with this Post
