17-01-2010, 11:03 AM | #1 | ||
5.6L x 2 pilot
Hi all. I am in the process of fitting my new whiteline swaybars to my LTD. I have managed to change the front on without drama, but I am having some difficulty physically removing the rear due to its shape an limited room to remove it.
Has anyone done this before? I am guessing I will have to disassemble the IRS unit in some way to be able to get the old one out and the new one in. I am just not sure what is the best way to approach this. Does anyone have some tips? P.S. The front 30mm adjustable has made a massive difference - even on the softest setting.
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
17-01-2010, 03:54 PM | #2 | ||
You have to drop at least one of the rear half shafts out. Even then it requires a bit of juggling. If you take both out it is a piece of cake.
17-01-2010, 04:09 PM | #3 | ||
5.6L x 2 pilot
Cheers T3man. Being an AU and IRS newbie, are the half shafts much work? I have a Max Ellery workshop manual, but it does not say much apart from mentioning special tool number xxxxxxxx for the cv boot replacement.
17-01-2010, 07:34 PM | #4 | ||
You have to remove the wheel. Remove the strut. Remove the hub carrier. Then you can slip the shaft out of the diff.
