27-08-2005, 03:14 PM | #1 | ||
Nat D
for an au falcon to fix the windows.... where do u get it from?
27-08-2005, 03:23 PM | #2 | ||
I've seen it at Supercheap and Autobarn at least, i'd presume most places like that would keep it
Cheers, Phil |
27-08-2005, 03:48 PM | #3 | ||
Yeap, most automotive shops should have them, I get mine from Supercheap like said in the post above, and its great for refreshing them rubbers when they start to stick. Some people also use it on body plastics for its shine but I notice it seems to attract the dust a lot more.
The way i applied it was, pull of the door trims, if the spray didn't come with the tubular nozzle, grab one from a WD40 spray (purge remainig wd40) or if ya really pov, use a maccas straw. Then I would start on the inside rails, high up. This is where it is most likely to stick. Open and close the window a few times, and if it still sticky moving, work downward, making sure you use it liberally. |
27-08-2005, 04:25 PM | #4 | ||
Custom user title
MRsheen works great on window rubbers and doesnt wreck the rubber like silicone does
27-08-2005, 04:52 PM | #5 | ||
Nat D
yeah well i got some at bunnings hardware in case anyone else wants to know..
30-08-2005, 09:14 PM | #6 | ||
I bought some at Bunnings last weekend for about $10. Its called ezy glide and often used to lubricate roller doors. I to used it to fix the power windows.
31-08-2005, 05:59 PM | #7 | ||
AU - YEA YOU!
So do you just spray the stuff inside the window rubber with the window down or do you have to pull the door trim off?
AU II XR6 VCT - JMM DEV3+
31-08-2005, 06:02 PM | #8 | ||
Nat D
spray it in between the rubber down the sides of the windows...
31-08-2005, 06:39 PM | #9 | ||
Giddy up.
I just used Inox.
31-08-2005, 06:42 PM | #10 | ||
Custom User Title:
I couldn't find it in any of the auto stores in sydney, ended up getting it in kmart of all places.
____________
Just sometimes, in between the first cigarette with coffee in the morning to that four hundredth glass of cornershop p**s at 3am, you do sometimes look at yourself and think... this is fantastic. I'm in heaven. |
31-08-2005, 09:14 PM | #11 | ||
Mondeo Titanium Estate
Just had my 2 front doors done today when my car was in getting serviced by a ford dealer.I told them about the windows going up slowly and i asked if they could squirt some lube in there thinking it was part of the warranty, come back in the afternoon to pay for the servive and the bloody smucks charged me $24.10 for lubing the door runners. ****ed off, I think i will head off to the auto shop next time and do it my self. Lesson learned!
01-09-2005, 02:20 PM | #12 | ||
Custom User Title:
Well now you know. I feel for you that you had to learn the hard way. Ford Servicing is a rip off unfourtunatly.
____________
01-09-2005, 07:21 PM | #13 | ||
Giddy up.
$24.10 for that, gezz. rip of merchant's.
01-09-2005, 10:28 PM | #14 | ||
FishermanDan
Should of asked them for the remaining contents of the can ;)
02-09-2005, 07:22 PM | #15 | |||
Now a turbo man - sort of
04-09-2005, 10:55 PM | #16 | |||
Former BTIKD
06-09-2005, 10:36 AM | #17 | ||
Custom User Title:
Vasoline apparently works well also.
____________
06-09-2005, 11:18 AM | #18 | |||
06-09-2005, 11:21 AM | #19 | ||
Custom User Title:
Well I actually said vasoline, not valvoline, but close.
Vasoline, you know what I mean.
____________
