Old 08-05-2010, 09:56 AM   #1
diatribal08
diatribal08's Avatar
Default Sports Bar Fitting
Hi any of you guys know an easy way to fit the sports bar bolts behind cab ? its a pretty tight fit and my pudgy fingers dont fit. Im holdin off loosening the tub bolts and using a jack but if thats the only way??
diatribal08 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2010, 12:50 PM   #2
DW260
DW260's Avatar
Can you grasp them in some pointy-nose pliers?
FPV GS Ute #370/Brembo brakes
DW260 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2010, 02:38 PM   #3
diatribal08
No the angle is too extreme, tried a magnet thingo and bluetac on the finger ...no go
Old 08-05-2010, 08:48 PM   #4
I once fitted a sports bar to a BF II and it was one of those "why did they design it this way" jobs. Absolute pig of a job. The instructions noted that you should jack the car up between the cab/tub to slightly "flex" the join to allow a little more access to the bolts. I ended up sticky taping the nut to a welding rod/peice of wire to hold nut whilst carefully threading onto the bolt.
Old 09-05-2010, 09:00 AM   #5
diatribal08
Sounds like thats the next move , ill try jacking the ute up and the welding rod trick Cheers
Old 09-05-2010, 10:38 PM   #6
cedric
yeah i was a bit alarmed when the instructions said jack in the middle and bend the car!!!!!!!!!!
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2010, 12:49 PM   #7
diatribal08
Worked BRILLIANTLY Cheers mate , now the back sint vibrating like buggery any more
Old 10-05-2010, 02:24 PM   #8
Glad to here all worked out. It really is one of those jobs!
Old 11-05-2010, 09:37 AM   #9
diatribal08
Yup wont be doin that again in a hurry, still was less painfull than replacing the high pressure power steering hose....lol
Old 11-05-2010, 09:29 PM   #10
naddis01
naddis01's Avatar
Yeah it is a PITA to put the sports bar on. I bent a spanner to the right shape to fit in there.
naddis01 is offline   Reply With Quote Multi-Quote with this Post
