30-09-2010, 12:12 PM | #1 | ||
'06 Ford Territory Turbo
I was wondering if anyone knew where would be the best place to buy a "Drive Belt Idler Pulley Assembly" from?
Its the pulley bracket that replaces the air-con compressor if you choose not to use the air-con. |
30-09-2010, 12:23 PM | #2 | ||
Either from ford, if they still make em, or make one up your self,
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
30-09-2010, 02:29 PM | #3 | ||
AFF Whore
Try Bursons, they've always had whatever I've needed.
