Old 17-10-2005, 05:32 PM   #1
xbcoupe302
formerly xbwgn
Default lead filling
Not sure if this is in the right section but i couldnt find a section on bodywork.
does anyone know the process of lead filling as i would like to do this to my car as it has quite a bit from the factory.
dont want to use bog if i can help it i asume u melting the lead to the part u need to repair but do u need to heat that part of the panel up aswell???
any help appreciated.
Member of the 250rwkw club.
weekend driver XB COUPE
daily driver ZH FAIRLANE
project cars V8 XB WAGON
V8 WINDSOR POWERED BLUEBIRD WAGON
wrecking v8 XD WAGON
xbcoupe302 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 08:32 PM   #2
wulos
Forum Director
wulos's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind-the-scenes effort. Technical Contributor: For members who share their technical expertise. - Issue reason: For his advice, tips/tricks in the Art and Photography section of the Forum.
Lead wiping is a process very similar to soldering. You will need to get both parts hot enough for the lead to want to adhere to the surface, but not so hot as to run off. tis a fine balancing act. You'll find that a lot of old school electrical cable jointers will be able to give you a whole lot better insight into this then I.
Need to remember , that whilst the lead is a metal, & won't deform(if done correctly) the lead itself is somewhat hazardous & will add additional weight to the car) Still is a VERY traditional car building process.
wulos is offline   Reply With Quote Multi-Quote with this Post
