any thoughts/opinions?
cheers Shaun Current SY FPV F6X Territory #214 Previous FG MkII G6E Turbo built by Heinrichs Performance and Tuning BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning "Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger |
rexnet
i think both are restrictive for memory. see paul and get him to slap on some pacemaker's
RIP...
I have a feeling they're the same.
In any case, short 4-1's like that are crap. A decent set of tri-y's are best for all street use, brands like H&M, Advance, Hurricane, Genie, and Lukey, all make sets which have good tube size and length.
. Oval Everywhere... |
I can pretty much get a set for the price of a smile so it was worth asking.
Yeah, when my house/bills stop hogging my cash flow allows me ill get paul to hook me up with some headers and CAI stuff too.
#5 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
These are stock 220 against stock T3 apart from the HP coating they are the same , you may be able to compare the 200s against the pictures
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
rexnet
are they pretty restrictive Whoosha? i dont know much but they kinda look like they all get put into 1 pretty quick.
Giddy up.
The 200 and 220 kw factory header's are the same, although I have seen one set from a 220 (susposedly) that was larger in the pipe exiting the cat then my old 200kw ones, but I have also seen other's from a 220kw that were the same diameter.
But in general they are identical, so if you are looking to get a gain going from 200kw to 220kw factory header's, quite simply you wont. |
#8 | |||
Giddy up.
not here much anymore
The factory ones are great headers if youre looking to make the car dull and boring.
RAM 1500
#11 | |||
RIP...
The primary pipes are way to short, and they aren't tuned length. They are used from factory because they're cheap to make, easy to install, and a little better than an old style cast log manifold. A much longer primary pipe, and tuned lenght will improves things. Good tri-y's will improve things even further.
#12 | |||
RAM 1500
#13 | |||
RIP...
#14 | |||
AU DIE HARD
Well with out getting into the pros and cons of it all
![]() ![]() and sorry Sox the T3 set will probably end up on a XR8 Cortina ![]()
