Old 05-10-2011, 02:43 PM   #1
Cadge
Default Mini Spool Vs LSD
Hey guys,
As some of you may or may not know i currently race an AU off Road. It still is an open Spinner Diff, and was looking into either fitting a mini Spool, or LSD.
Im leaning towards a mini spool, as it seems to be a hell of a lot cheaper, for the same result, but saw a friend who had a mini spool in on a 25 spline commodore diff, snap a couple of axles.
Would a 28 spline be stronger? I dont want to be constantly swapping over axles.
Thanks
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box|
Cadge is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2011, 05:16 PM   #2
Sox
RIP...
Sox's Avatar
Default Re: Mini Spool Vs LSD
If it's used only off road, a mini spool would be my choice.
Mini spools break stuff on the road because there's no give around corners. Big sticky tyres will snap axles.
They're also pretty dangerous in the wet.
I wouldn't use a mini spool on the road, so if the car is dual purpose, then an LSD is your only choice IMO.
Oval Everywhere...
Old 05-10-2011, 09:31 PM   #3
Beer Baron
I agree. Mini spool for off road and LSD for on road.
You may need to adjust your wheel alignment settings too after you install a mini spool.
On road mini spools accelerate trailing arm bush wear, Can twist axles then sheer them off, defectable, can be dangerous in the wet and in car parks people look at you funny as you turn in.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 12:02 PM   #4
Cadge
Yeah we have one event a year that is tarmac...
Time to look for a cheap LSD... Im guessing EF/EL LSD wont fit into an AU? just seem alot more common than the AU ones.
Is $500 a good price?
Old 06-10-2011, 12:16 PM   #5
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
Are you looking for an LSD centre or entire diff?
As long as the diff is live rear and not IRS, its possible to fit one from an EL into an AU. But don't quote me on that.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
2018 Hyundai Santa Fe Highlander
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 01:59 PM   #6
Cadge
Interesting... Will have to do some research on that... Am i right, to tell the difference, when you bounce the car, IRS will not move with the car, but live axle will?
Old 06-10-2011, 02:56 PM   #7
jrfttf
Getting By!?
jrfttf's Avatar
spool if always off road imo
jrfttf is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 03:20 PM   #8
blueoval
Critical Thinker
blueoval's Avatar
Ah, I generally can tell the difference by looking underneath the car. The IRS diff has suspension joints in the diff that move independently to the diff centre. The live rear is one solid unit and only moves when the springs and shocks let it.
Live rear axle
IRS rear axle
I still dont know about the centers being interchangeable.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 06-10-2011, 04:18 PM   #9
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
EF/EL Diff will fit, but you will have the offset change, so running pre-au offset rims will be needed...
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 04:30 PM   #10
blueoval
Critical Thinker
blueoval's Avatar
Is there a difference with offset for the rear? I thought the offset was nil on EL to AU diffs. Only the front had the different offset?
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 06-10-2011, 04:36 PM   #11
XRGhia
meh.
XRGhia's Avatar
Nope, rears had a different offset, which is why many people with E-Series who are running a Cebco/RBS front twin piston brake upgrade kit, generally tend to upgrade to an AU diff to give them AU onwards offset all around...
Old 06-10-2011, 04:48 PM   #12
blueoval
Critical Thinker
blueoval's Avatar
Ok no worries. Cheers for clearing that up
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 06-10-2011, 10:05 PM   #13
FGII-XR6
FGII-XR6's Avatar
if that was the case all AUs would need different rims front and rear the and you mught find scrutineering problems with the wrong offset. if you are going in a straight line a mini spool is ok if you are turning corners they are bad for the car, the road and can be dangerous as they can make your handling unpredictable when the rear tyres skip during turns
[SIGPIC][/SIGPIC]
Rides:
Old 06-10-2011, 10:10 PM   #14
atec77
Hey guys,
Thanks
I have one of these in my bimmer http://en.wikipedia.org/wiki/Torsen awsome thing and very quite
Old 06-10-2011, 11:39 PM   #15
Cadge
how much did you pay for once of them?
