07-12-2011, 02:13 PM | #1 | ||
Hi. This will make a change from all the high tech questions at least.
On the front under flat spoiler of the AU and our new falcon there is a flat vertical tab right across the car. In my humble opinion I feel this would act like a sail brake and be counter productive in many ways. It bugged me so bad on the AU I trimmed it off! But before I do same to the Anniversary I just wanted to know if anyone out there knew of an intelligent reason to leave it there, I won't. |
07-12-2011, 02:14 PM | #2 | ||
Last warning
helps to create a low pressure zone in the engine bay - aids radiator flow
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
07-12-2011, 02:20 PM | #3 | |||
Performance Inc.
I think that lip is there to give strength to the trailing edge to stop the air deflector flapping in the breeze and falling apart as the rear section is not otherwise attached to the car.
In The Garage... FPV Super Pursuit Build no 0080/91 Lotus Exige S/C S240 Kart Hasse Chassis 100J Power Quote:
07-12-2011, 02:22 PM | #4 | |||
Afterburner + skids =
07-12-2011, 07:01 PM | #5 | ||
Im sure all that wind tunnel testing musta been a waste of time....
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
07-12-2011, 08:41 PM | #6 | ||
Both reasons apply I reckon.
Cut it off and see how dirty your engine gets.... |
07-12-2011, 09:03 PM | #7 | ||
The intelligent thing is to leave it there. As mentioned, it helps extract the cooling air from inside the engine bay while driving along.
07-12-2011, 10:03 PM | #8 | ||
XA GT
I pulled the whole black tray off, engine isn't dirty, it doesn't get hot and I can't see any differance with it off.
--------------------------------------------------- XA GT, 6.848sec 1/8 mile @ 101.68mph |
07-12-2011, 10:15 PM | #9 | ||
powered by Ford
Its definately there to pull more air through the radiator (don't know about the dirty engine theory?).
07-12-2011, 10:40 PM | #10 | ||
There is a bit of logic here as to stay Jewish or do da big cut.
But at the end of the day if this tab is possibly for radiator cooling, then 'at speed' it wouldnt be needed anyhow. I will check for strenght first. This flat 'cooling, aerodynamic and engine cleaning tab' on the FG is quite big at about 1" wide and I am now at 80% 'it has to go'. As such I think it will be 'Wide Bar Kuts'mah' Aussie style, with Home Brew all round. I will drink to it meanwhile as I ponders. |
07-12-2011, 11:07 PM | #11 | |||
07-12-2011, 11:14 PM | #12 | ||
I remember reading in a guide to modifying WRX's that many owners are surprised when they lower the suspension, fit stiffer springs and roll bars, and play with the camber, that they end up with something that handles like a pig.
Occasionally, just occasionally, the guys who spent hundreds of millions of dollars developing something had a vague idea what they were doing... |
07-12-2011, 11:17 PM | #13 | ||
spoolin!
Is it really that much of a problem?
Current Ride - 2016 FG-X Falcon XR6 Turbo Manual. Smoke Grey Previous Rides - 2014 Black Mica PX XLT Ranger Dual Cab 3.2 Diesel 2011 FPV GS 315 Sedan. Sunburst, manual, fully optioned. Build #165. My 1955 Ford Thunderbird Project (A tribute to my late mother) - 1955 Thunderbird Build Thread
08-12-2011, 08:54 PM | #14 | ||
FG XR6T trayback
If it did SFA, Ford wouldn't have put it there, and saved a few buck.
08-12-2011, 09:01 PM | #15 | ||
Barra Turbo > V8
I dont get the issue really, its not that much of a hassle, although it might save you 0.00000000000000000000000001L/100 in fuel
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
08-12-2011, 11:07 PM | #16 | ||
It also helps keep the underside of the front bar more rigid.
09-12-2011, 12:55 AM | #17 | ||
its suprising that things like this can make sutch a difference. one example is the rear spoiler on the old GT40, it looks like something that would slow the car down by inducing drag, but without it at high speeds the car would become so unstable it could crash.
This may not be the case with the lip on the front of the falcon, but im sure its been put there for a reason & im with everyone thinking it has something to do with cooling |
09-12-2011, 10:46 AM | #18 | |||
I don't think so! |
