Define definitive
hey everyone, getting new headlight globes tomorrow and wondering which ones i need
these:http://www.supercheapauto.com.au/onl...97#Description or these?:http://www.supercheapauto.com.au/onl...92#Description
BF F6 TYPHOON in NEO #718 ~ 356rwkw ![]() BF XR6 TURBO in SILHOUETTE |
H4 main beams (low & high - outer lamps), H1 high beam (inner lamps)
You need both of those. However be aware that the brand Calibre is Supercheap's "home brand" and may not be as good in quality as say Philips. I have a full set of Philips Crystal Vision globes to suit your application (left over from a group buy). PM me for a very good price if you are interested.
Define definitive
thanks mate, ill have to get both then lol
Oops, sorry I just checked the ones I have left and they are one pair H4s (high/low - outers) and one pair of H3s (high beam/driving - inners).
#6 | |||
Define definitive
When in doubt, GAS IT!!
I wouldn't touch Calibre with someone elses barge pole. The quality control is iffy to say the least and the light output for the wattage is ordinary. If you're going to spend the coin then get a name brand at least. Phillips are top of the tree and excellent lights but you pay a premium for them. For what you want, Narva is reasonable value, put out good light and at least the quality is consistent and they'll put the filament in the right place. If you're going to spend up on Phillips may I suggest, for your H1s', go online and pick up a plug and play HID kit from Ebay. You can pick them up for under $100 and they'll out perform any halogen globe by 3-400%.
Bushbasher
rexnet
im pretty sure a friend put these in his WRX and theyre really white and give out super good light.
http://www.ebay.com.au/itm/1-pr-H4-G...ht_1986wt_1396 |
#9 | |||
Bushbasher
Define definitive
so ill get some lights tomorrow. just noticed in autobarns cataloge they have phillips blue vision for $49.99. thinking these will do
rexnet
i've herd Phillips Crystal vision is also a winner.
#12 | |||
#13 | ||
not here much anymore
Have used both the Blue and Crystalvision and currently have Crystalvision in the ute. Happy with them but the performance of the bulbs isnt as good as it was in the FG (They were awesome), I put that down to the different headlight types.
RAM 1500
#14 | |||
Cheers Bushbasher
#15 | ||
Yep, that's exactly what happens - it isn't until you fit a brand new one that you notice how dull they have become. I only noticed it because I had to replace a blown globe which had only been fitted about a month or so earlier (did two new globes at the time) and when I did I noticed the other "new" globe was heaps duller. I then did some back to back tests with both H1s and H3s in various driving lights and found it was common across all the Narva range. In fact in the driving lights (which when used are generally on for extended periods) the dulling was even more rapid than in the H4s.
#16 | ||
Well there ya go eh, I'll take your word for it. Good thing I converted the wagons' Narva 175 driving lights to HID then, lol.
Cheers Bushbasher
#17 | |||
I use Philips Premium H4's std 65/55W in all my vehicles, I found long ago it's not so much the globe it's how good the lamp itself is and aimed properly. I just replaced the lights in my AU with new ones (but used same globes back in them) and the light output is amazing without causing glare to oncoming. Have nice sharp cut off points again like new etc etc It's illegal to have HID conversion kits in main headlights (separate factory high beams or spotlights are ok) The reason is because non HID lamps are designed for halogen globes and the reflectors in them cannot direct the light from an HID globe in the right directions. I've seen plenty of bad examples blinding me, they get the full force of my big HID spottys ![]() |
