Hi guys...
I need to replace the reading/ courtesy lamps in the front but I don't know how to get the unit out without damaging the plastic. It is the console that also holds the sunglass compartment. The two round lights and the two switches seem to be clipped it. But there is no gap where you could squeeze a fine screwdriver in. Is there a trick to it? Do I have to push or squeeze at a certain spot to make it come out? Or do I have to use a string/threat. Thanks for any ideas The Moose |
#2 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Fine blade screw driver from the front (Windscreen side) gently twist and it will pop out from the Glasses holder
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Flairs - Truckers Delight
i just pull em out *shrug*
