Old 03-03-2012, 06:08 PM   #1
FreddyDUZ747
FreddyDUZ747's Avatar
Arrow EL Falcon leaking fuel from regulator
Found my little issue regarding startup,the rail/reg is leaking.It seems to be coming from the regulator and looks to have a gasket or O'ring sealing it to the rail,is this correct.
I have removed throttlebody etc and when primed I can quickly run around and see/feel the leak coming from the reg area,you can also here a pshht sound for a little while whilst its releasing what pressure is left in system.
So,does it sound like im on the right track with the reg leaking?
BTW,we are loving the ride in this carI keep finding replaced/better parts throughout the car,saw the new nolathane front end in it today.
Cheers guys and gals
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2012, 08:39 PM   #2
FreddyDUZ747
Default Re: EL Falcon leaking fuel from regulator
I have found the oring to be the problem.
Is this a part thats universal or it has its own part number?Im hoping Champion or something sell them in those plastic packets you see on the spinning stands in autoshops.
Old 03-03-2012, 09:15 PM   #3
smally289
growing up is optional
smally289's Avatar
It would be listed with it's own part number. Be better to get the right one than take a chance with something generic.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2012, 09:29 PM   #4
FreddyDUZ747
Bummer,hope its something stores carry on a regular basis.
Its not a genuine part anymore is it,bit old the EL for them to carry the part I would have thought?
Old 03-03-2012, 10:29 PM   #5
smally289
smally289's Avatar
You may be surprised as the o-ring in question may have been carried over to later models, possibly for a different component. Try your local Dealer (Ford, not drug!)
Old 03-03-2012, 10:36 PM   #6
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
it is the same as an 'e' series or AU injector o'ring?
i have a few spares if you need one, im down south though
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2012, 10:47 PM   #7
FreddyDUZ747
Thumbs up Re: EL Falcon leaking fuel from regulator
I thought today was Sunday lol so late this arvo I took everything off thinking tomorrow being Monday ill find one somewhere.
Injector oring...it looks to be exactly that.
Old 03-03-2012, 10:55 PM   #8
FreddyDUZ747
Thats very generous of youbut I have a backup hack now also.
We will just get by I recon with the 3rd car lol(1990 Laser)I think if I cant get one local tomorrow till Monday.
Not sure she would make it up the hill tbh
Old 03-03-2012, 10:59 PM   #9
my67xr
my67xr's Avatar
they are about $2 from repco etc
was just thinking too, with the regulator
if you find a small socket that fits snug over the vacuum pipe on the top of the regulator.
sit the reg on something solid, slip the socket over the top and tap it with a hammer.
if you can move the base down 1-1.5mm it increases the fuel pressure about another 25 psi,
may be useful when you want to start making a bit more power in the EL.
67 XR Fairmont
Old 03-03-2012, 11:03 PM   #10
FreddyDUZ747
Nice,ill buy 3 or 4 spare also
Old 03-03-2012, 11:19 PM   #11
my67xr
my67xr's Avatar
btw, hope im not out of line posting in this thread 0zECruisers
ps; if you are looking for another cam for your EL, i have a couple i may sell,
a Crow and a Wade, both suit standard auto ecu.
also i have a set of AU injectors that'll slip straight in too
67 XR Fairmont
Old 04-03-2012, 12:14 PM   #12
FreddyDUZ747
All fixed,got them from sprints this morning.They are indeed an injector o'ring.
Thankyou for all suggestions.
67xr,ill be in touch
