#1 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Just a quick question.. and yes I did the usual searches
![]() the service spanner that appears on the dash on the S1 Au does it disappear the same as the EF ? From memory, key to acc. and hold the speedometer button in. if not how so please ![]() Thanks in advance Whoosha
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Walking with God
That's it. Accessorites on, then hold in the button for a bit, until it beeps.
GK
AU DIE HARD
Ta George Been a while and old age is setting in
Formally kotevski22
Ignition on hold until it beeps about 15 seconds.
#5 | |||
#6 | ||||
Former BTIKD
![]() Join Date: Mar 2005
Just tried it on my Dad's AU & it didnt work. No beep. And spanner light is still on.
Current: Toyota JZX90 Mark II Tourer V 1JZ-GTE Nissan Fairlady 350Z Nissan Skyline 370GT Coupe Previous: FPV BF F6 Typhoon #202 BF XR6 Rebel Founder of BA & BF FORD FALCON FACEBOOK GROUP |
#8 | |||
Walking with God
Sounds silly I know, but worth checking. GK
Tried it on acc, & on the next setting. neither worked.
Hi. From the "injectronics" web site for the AU
As with the EF and EL Falcons, the AU Falcon has a small light in the shape of a spanner that illuminates in the lower left hand corner of the dash panel when the vehicle is due for next service. The procedure to remove the service light and reset it for the next service interval is simple and Injectronics recommend to follow this procedure: Turn ignition on (don't start engine) Hold down the reset shaft for between 11 and 13 seconds An audible beep will be heard after the shaft has been released to indicate that the command has been received and the light should go out. Note: If the button is held down too long or not long enough, the spanner light will not clear. Cheers MD
growing up is optional
For some reason, the AU's seem to be time sensitive. EF/EL's you can hold the button in and wait for the beep before releasing it. AU's you have to release it before it beeps , try 12 or 13 seconds, may take a few tries to get it to work.
#12 | ||
Turn it on so that all the dash warning lights are on, don't start it. Hold the button in until it resets.
#13 | ||
And of course don't forget to do the service this light is reminding you to do..
#14 | ||
Isn't it ironic that such a 'modern' car uses an open ended spanner for a service indicator?
#15 | ||
Hello once again,
I must be sending my messages to the wrong section so I will try again. I need a 90mm air flow sensor to fit on my EB2 5lt with an upgraded AU series 3 XR8 heads,cam & exploerer manifold. The only place on the net is from the USA . Herrod Austrlia don;t have them anymore. If I get one from there do they wire straight into my conversion.Any help please Thanks from keno49 |
#16 | |||
start your own thread. In your case probably best in the Post Classic XD to EL section here: http://www.fordforums.com.au/forumdisplay.php?f=29 Use a good title such as "EB2 5lt 90mm air flow sensor needed" Last edited by AMB; 08-08-2012 at 03:18 PM. |
#17 | |||
#18 | |||
Walking with God
In my Series 1 Futura, I have the key on accessories, and simply hold the button in until it beeps. The icon disappears as it beeps. I don't count or anything. I just keep the button depressed until the beep. GK
#19 | ||
Broken reset button?
#20 | ||
Flairs - Truckers Delight
Just to clarify brett77777 that this is the orange spanner not the S in a circle
#21 | |||
#22 | ||
Series 1 ghia . Tried lots , only thing that worked was ...
Turn ignition to Acc . Hold button for 12 seconds ( using stopwatch on iPhone ) . Release button , spanner gone with audible beep ![]() Simply holding it never worked until it left .
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
#23 | ||
is the spanner service reminder thing a feature on series 2 models?
#24 | |||
#25 | |||
