Old 05-12-2005, 10:54 PM   #1
howey
Default analyse my time slip
Can anyone with experience take a look at my time slip and tell me where I would be falling down most. I know the times are slower than most of you would be used to, but what I'm looking for is one sector that stands out as not fitting with the rest. (The slip didn't scan well so I'll enter the data manually)
60 ft - 2.4633
330 ft - 6.5870
660 ft - 9.8854 @ 75.29 mph
1000 ft - 12.6674
ET - 15.0264 @ 95.56 mph
This was my last and quickest run of the day, many of the runs I had were marred by fuel starving, but this one was a full power start to finish pass
howey is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2005, 11:01 PM   #2
Damo
what kind of car ? Auto manual etc ? That's good MPH, should see mid 14's with a better 60 ft time.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2005, 11:19 PM   #3
xr8ute
Back on the road
xr8ute's Avatar
You've got good power (95.56mph), but you are pretty ordinary off the line (2.4633s 60').
I was doing 14.544 @ 95.25mph, with a 2.170s 60'...
Can you tell us more about your car?
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 12:56 AM   #4
Stav
Smile
Stav's Avatar
You have the opposite problem to me.I pulled a 15.1 at 90mph but got 2.177 60ft. Your low down acceleration isnt going so well but I wish I had some of your power.
Old 06-12-2005, 12:30 PM   #5
darnoldrs
had mine at the drags. the differance between a good 60ft time and bad =
2.4 60ft-ET 9.7@76.92Mph 1/8th mile compared to a
2.1 60ft-ET 9.2 @77.59Mph 1/8 mile.
Im not an expert but you should be able to get down to a 2.0/2.0 60ft times. I have done a 2.060 60 ft missed 3rd and still got a 9.247 @ 74.74Mph. So a good launch and 60ft times are esantial.
What is your reaction time??
darnoldrs is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 01:32 PM   #6
Walkinshaw
Two > One
Walkinshaw's Avatar
your 1/2 track MPH indicates you have the power to get the car up to speed, are you having traction problems, or is the car bogging down off the line.
What does your car weigh, and what gearing/drivetrain does it have. Nigh on 96mph should be netting low 14's (in a falc)
Old 06-12-2005, 01:46 PM   #7
jcxr
Tribal Elder
jcxr's Avatar
You need ahi stall or lower diff ratio
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 05:30 PM   #8
rodderz
rodderz's Avatar
Your 60 foot time needs improving by a lot, if you can get that close to 2.00 as possible you'll get a great time. Some people use the rule that .10 sec off your 60 will result in a .30 off your ET
What sort of car, and was their wheelspin or bogging down off the line?
rodderz is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 07:26 PM   #9
Craig
RIP Craig - 13/11/08
Craig's Avatar
Mate,
Need to know what sort of car, auto or manual, what tyres.
Your sixty footers resemble a tractor.
Craig is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 09:03 PM   #10
howey
Car is an xd ute. 351 clevo. C10 auto, 9" diff 3.5:1 ratio. The car actually belongs to my brother in law, but I had it fr the day. The conveter is supposed to be 2600 rpm, but on the line with foot pushing through the firewall on the brake, I could only just crack the throttle, bring up 1900 - 2000 rpm before the wheels would turn. It has had traction problems earlier and had actually gone 14.6 with wheelspin and 3.7:1 borg warner diff. We bought a set of secondhand drag radials off a fellow forums member which are 245/60 14. There was no traction problem at all on Sunday.
Thanks for all your replies. The common theme in your responses seems to be the 60 ft time sux, so I'm guessing the converter is a big issue.
Old 06-12-2005, 09:15 PM   #11
naughts
Hmmmmm Mulberry....
naughts's Avatar
Crap 60 ft time
I run same MPH and run 14.5 but 2.1 60 ft. I run a 2500 stally
naughts is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 09:59 PM   #12
302donk
302donk's Avatar
up the stall and the diff gears dude and should see some inprovement
302donk is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 10:53 PM   #13
jd dad
Good to see the tyres are working ok. Try it without any stallup at all ie just a bit above idle then floor it. Know with my Capri with 2400 stall it would die when stalled up but just mash it on the start and it was heaps better.
successfull trades with davway,ozziechief,Damon, Big Trev, Howey, BJ , Niko, Davocol,klawsterfobik and XCwillo
jd dad is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 08:30 AM   #14
Bluepower
KenneBell Australia
Bluepower's Avatar
What size camshaft Howey?
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 06:47 PM   #15
howey
The cam is a crow hydraulic grind number 21649 at this page http://www.crowcams.com.au/templates...leveland.shtml
