DFDFDF
Hey guys,
Any one able to help me out with identify what these connectors are and what should plug into them? They are the last ones I need to work out.. One of them I am sure is for the indicator stalk, but the stalk I have doesnt fit any of them.. :-S ![]() ![]() ![]() Cheers, Nik
The Daily : 2012 Ford Territory The Restorer : 1994 Polynesian Green ED XR6 T5 - Completely stock, put away for a few years The Project : 1994 Velocity Blue ED Ford Futura - AU3 220kw XR8 5L V8 5-Speed in progress The Toys : 2003 GasGas EC250 & 2001 Yamaha DT230 |
Boost Addict
are the underneath the drivers dash part?
even thou I was under my dash 2 days ago I cant say which ne is which but I could a,most swear i have seen them. One loos like for the controls for steering wheel column, and another one for the fuse panel.
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
DFDFDF
Yer the orange and black ones are under the dash near steering column and the blue one is under the dash near the radio panel...
The indicator stalk I have has a similar connector but it doesnt fit either of these... :-S Cheers, Nik
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
Roosta, see if these connector diagrams help.
http://fordforums.com.au/wsm/wire/aubx/Part%2024-3.html The wiring diagram pages also show the location of the connectors. Good luck. Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
DFDFDF
Thanks Stu..
Yer had been through all of them but after half an hour of having my head tilted it started to get sore, and seeing as i couldn't download it and print it I gave up using the tech resource... Cheers, Nik
Lacking Imagination
Okay.
Orange appears to be C-33, which judging by this pic, is for driverside around steering coloumn. ![]() the Black and blue (C-189) is for the airbag module which sits infront of the shifter ![]() and the black one looks to be (C-198) .. which i cannot find atm..
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W Last edited by FAT245; 24-03-2013 at 05:44 PM. |
Lacking Imagination
C-198
![]() Looks to be for the heaterbox?
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
DFDFDF
Hey Nathan,
Thanks mate.. I'll pay you credit for the Orange and the Blue.. But the black one is also located under the steering column, and the heaterbox one is accounted for.. I am think C-158 might be the black one but until I colour match the wires in the back of it I guess I wont know.. And the 'column switch connector' c-167 matches the indicator stalk i have.. What I do know is the 'AU' Indicator stalk I have been given aint plugging into the loom I have.. :-( I totally should have just bought a full car to utilise... Might still have into look at that.. Cheers, Nik
Lacking Imagination
My coloumn has two connectors underneath, which i think runs upto that connector... not sure exactly but it there might be an intermediate cable?
DFDFDF
Hmm.. Will have to check it out on an actual car..
Also in the tech resources it doesnt list what series AU the connector diagrams and wiring diagrams are for.. Should I take that as series 1, 2 and 3 are the same loom, but with different accessories attached? Cheers, Nik
Lacking Imagination
the Loom is a S2, So I cannot exactly say.
