Old 31-01-2009, 08:41 PM   #1
Whoosha
AU DIE HARD
Whoosha's Avatar
Cool Ball Breaker
Just when you think things are going good, I get the phone call from number 2 son,"cars making realy strange noises and it wont steer straight" (AU111SR)
Well have been away all week so haven't had time to scratch myself, so decided it would be easyer to get it towed from Melb. CBD back to Cranny . So finally got home to have a look at it this morning only to find this mess
it would appear that the lower right ball joint gave up with little or know warning, Lucky it was only in the city at low speed and not on the freeway at 100kph as the wheel locked as it chewed through the rotor : Oh well what beter way to spend a 35c day but under the car ..the cars only has 160000s on it so was a bit surprised.. in the good old days a grease nipple or 2 would have saved it I'm sure :
On another note I am giving the car a full going over and service while its hear and have found a nasty oil leak from around the water pump someware,did a bit of a search but haven't come up with much info on this being a problem or ware it may be leaking from so before I pull half the front off the motor I would check here first. restasured I have checked the usuall rocker cover gaskets ext. but just carn't seem to pin piont ware its coming from.. Thanks In advance Whoosha
Originally Posted by Riksta
Old 31-01-2009, 09:24 PM   #2
Stav
Smile
Stav's Avatar
woosha.. Get a 10 mm socket ...gently tighten your timing case bolts. Also you may find an alternator bolt actually leaks oil.. Any way start with the timing case and the degrease it
Old 31-01-2009, 09:40 PM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
Its soaking in Kero as we speak thanks Stav
Old 31-01-2009, 10:02 PM   #4
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
yeah thats no good mate, when my balljoint got really worn it was doin similar, i just got to earlier. pretty rough.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2009, 10:05 AM   #5
domnicosia
Thats a serious failure of a ball joint!! Don't you guys have a yearly RWC down in Victoria? Ball joint normally become quite obvious way before they get to that state.
Scary when you thing of the possible out comes of that mate!?!!
Dom
domnicosia is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2009, 12:03 PM   #6
kcej
2mny projects 2 lttl time
Default Power steering fluid????
Mate is there any chance your "oil" leak might be power steering fluid?
Just a thought
kcej is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2009, 04:38 PM   #7
5.0 ED
5.0 ED's Avatar
Actually domnicosia we dont have yearly RWC. but i can tell u straight my lower balljoint was still good 2 weeks earlier when we had car on hoist checking everything, and then later that week i was driving, it deleloped a squeak, a couple days later when turning it started grinding on the disc, which i heard, pulled wheel off to find it. When these go like this, there really is very little warning.
Old 01-02-2009, 06:22 PM   #8
Whoosha
AU DIE HARD
Whoosha's Avatar
As Matt has said no warning at all realy we had new tyers fitted 2 weeks ago
and all was good then , anyway all done now just came inside got all cleaned up so I can go to work for a rest,Off to Rockhampton in the AM
The pesky oil leak turned out to be the timing chain tensioner after numerous hours of pulling things apart I found it behind the power steering bracket .FFS who thawt that one up.Some how it had come loose and undid its self So did a bit of a search of the forums found the "How Too" and did it, put some new brake pads in it while it was apart. gave it a wash N polish,Then thought to myself no wonder #2 son keeps bringing it back home for repairs : :
its in behind all this
pesky thing
All done
Old 01-02-2009, 08:21 PM   #9
AU1XLS
AU1XLS's Avatar
Good job whoosh, which car do you want next week the wagon
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2009, 10:07 PM   #10
Kev_BLNXR8_Ute
Hmm Project XW VAN !!!!
Kev_BLNXR8_Ute's Avatar
Im pretty sure the only wagons you have are from the wrong stable........
Just dont think he would stoop that low...
Kev
I'd rather be BLOWN than stroked
Yella Terra Supercharged
Power Output?
ENOUGH TO BREAK EVERY THING MORE TIMES THAN I CARE TO COUNT
POWERED BY VISA MASTERCARD AND MORE VISA
(And now a mortgage extension)
Disclaimer :
: Anything that seems or sounds illegal is all in my head and due to an over active imagination... :
Kev_BLNXR8_Ute is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2009, 10:14 PM   #11
naughts
Hmmmmm Mulberry....
naughts's Avatar
I'll bring mine over Woosha. whats the address???
naughts is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2013, 02:05 PM   #12
BigJamo
Yep ... BOOSTED
BigJamo's Avatar
Default Re: Ball Breaker
Damn, that could of been deadly at high speed.
Im glad I got my Balls fixed earlier. Would hate to drop them at 110 :0
BigJamo is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2013, 10:03 AM   #13
FGII-XR6
FGII-XR6's Avatar
Dom
they can fail suddenly. mine was fine for my yearly RWC and the lower right started making a noise and the ball joint failed suddenly making a grinding noise on right turns. I caught it early enough that the rotor wasn't damaged but the guy at the suspension place that fixed it said he sees it a lot
[SIGPIC][/SIGPIC]
Rides:
Old 28-03-2013, 11:23 PM   #14
b2tf
not here much anymore
b2tf's Avatar
Hate it when your balls drop
RAM 1500
Old 29-03-2013, 02:56 AM   #15
robertjp
that happened to the wife's wagon, after having new a tire fitted and they said it needed a wheel alignment.
Drove to Ballarat that day, we were lucky.
robertjp is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2013, 10:15 AM   #16
FNQracing
RAGE Engineering
FNQracing's Avatar
Timely thread.
I have an AUIII and it was making a kind of creaking/grinding noise from the front end only at parking speed and steering load applied.
Jacked the car up to take a look, lowered it and noise gone?
Symptom of ball joints? Front end feels tight otherwise.
If it doesn't fit, use a BIGGER hammer
FNQracing is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2013, 12:45 AM   #17
Murph-51
Murph-51's Avatar
The V8's do suffer a little from heat soak down the drivers side as the headers are really close to it, which will make it "creak"
Murph-51 is offline   Reply With Quote Multi-Quote with this Post
