Old 19-04-2009, 01:09 PM   #1
cant
CANT !!!!!!!!
cant's Avatar
Default AU high idle ???? CAUSES ?????
My AU recently backfired on gas, now it wont idle on gas and idles really high on petrol, am looking for a cause, ANYONE ?
CHEERS CHRIS
-BA XR8 Ute-
Better to be late, than
VERY LATE !!!! :
YEAH HA !!!!!!!!
cant is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 01:30 PM   #2
cant
CANT !!!!!!!!
cant's Avatar
Have had a good look under the bonnet, cant see any vacuum hoses off or loose, have cleaned the throtle body also.
Its like the automatic choke is stuck on, but I dont have a clue about how the choke on these things work!
Any help would be appreciated. Cheers
-BA XR8 Ute-
VERY LATE !!!! :
YEAH HA !!!!!!!!
Old 19-04-2009, 01:46 PM   #3
StealthAu
check your accelrator cable, it can pop out of its housing a bit which results in high idle. check manifold bolts, make sure they are tight.
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 01:50 PM   #4
cant
CANT !!!!!!!!
cant's Avatar
Have been right over it, checked all vac hoses, intake hoses, manifold bolts and gaskets, have even disconnected the Battery hoping to reset the computor!
Still runs the same!
-BA XR8 Ute-
VERY LATE !!!! :
YEAH HA !!!!!!!!
Old 19-04-2009, 02:32 PM   #5
cant
CANT !!!!!!!!
cant's Avatar
Anyone ?
Need the car tomorrow
-BA XR8 Ute-
VERY LATE !!!! :
YEAH HA !!!!!!!!
Old 19-04-2009, 02:33 PM   #6
JC
Miami Pilot
JC's Avatar
What about PCV valve? Or the MAP sensor. It sounds like a vacuum leak to me, and they're the two I'd check first.
Ford Performance Club ACT
Old 19-04-2009, 08:15 PM   #7
Windsor220
Now Fordless
Windsor220's Avatar
If the throttle body is fully closed when its idling then it must have some sort of air leak.
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2009, 12:10 PM   #8
LG
LG's Avatar
Maybe check the ISC. I have a feeling, mine's being a bit faulty, on me. Gives rather high RPM at times.
AUIII Falcon Forte, with SIX Appeal
LG is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2009, 12:28 PM   #9
Cookie-XR8
SKID IT
Cookie-XR8's Avatar
i would say pvc
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba
Where the boost junkies hang out -Forced Ford Forums
Cookie-XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2009, 01:46 PM   #10
BillC
where is the PVC valve ?
BillC is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2009, 01:50 PM   #11
LG
LG's Avatar
I think he means PCV like JC said, it's on top of your rocker cover, towards the front. Make sure it's not loose there.
Old 21-04-2009, 01:56 PM   #12
Racecraft
they call me Tibbo
Racecraft's Avatar
disconnect the ISC and see if that has any affect on the idle
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2009, 09:17 AM   #13
BillC
Thanks LG, now where and what is the ISC ?
Old 22-04-2009, 03:36 PM   #14
LG
LG's Avatar
ISC is your idle speed controller. It adjusts your idle between low and high, depending on temperatures, etc. Sometimes it gets stuck open, leaving the idle on high. So if you disconnect it, you should just have the one idle level. Most people just have their's disconnected all the time.
ISC is bolted on top of the throttle body. It has a 1-2" cylinder on it, with a black knob. On there, you will see a plug connected to it at the back of it (closest to the windscreen).
Un plug it, and see if your idle comes down. If it still goes up high, you have a vacuum leak. If not, then take off that piece, and give it a clean out with some Throttle Body cleaner.
Old 15-05-2013, 10:48 AM   #15
Haboota
Haboota's Avatar
Default Re: AU high idle ???? CAUSES ?????
Just want to say thanks to all involved in this thread! My AU 5litre recently started stalling when cold, and when hot it would idle at about 1500RPM. Thanks to this thread, I disconnect the ISC and it went down to about 600-700RPM when hot, but still stalled cold. This morning I replaced the ISC and its as good as new! ALL FIXED!
Thanks so much for the info!
For those who will follow in my footsteps, here's a pic of the ISC unit in place on a 5Ltr
AU XLS Ute - 5 Litre 5 Speed - Exactly how Utes were meant to be!
Haboota is offline   Reply With Quote Multi-Quote with this Post
