Road Runner
Does anyone know what voltage range the temp sensor in a eseries v8 is? and is lower voltage = higher temp. What voltage do they sit at in normal conditions?
#2 | |||
Road Runner
cheers mate, any idea on what temp its suppose to sit at?
#4 | |||
Not sure about the 8's, but my 6 sits in the low 90's
the 8's use a slightly colder thermostat. they open like 2 degrees before the 6cyl ones.
Not sure what this is about. In the EA there are 3 temp sensors. Air manifold temp. and another for water temp for the computer and another water temp sensor for the temp. gauge.
A simple test is the resistance cold and the resistance hot. There is also a thermostat. |
