Old 06-09-2013, 07:49 PM   #1
azza11
azza11's Avatar
Default Pressures for normal radials
I have a mildly worked six in a XR wagon, i am running on the eighth, car weighs 1430 kg, my street wheels are 15x8 welds prostars with 255/60/15’s, i also have a pair of 185/14’s on my original steelies. I was going to fit these up when i drop the pipe, to me they have less roll out and should help it off the line by being smaller, wheels spin will not be an issue, not enough HP for that, the 14’s i figure should get me to the finish line quicker but i wondered as to what pressure i should run. I am changing the wheels at the track as car is to low to drive normally with the 14’s on, track only wheels.
1967 XR Falcon Wagon, Super Pursuit…….for now.
*****XR PARTS WANTED*******
azza11 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2013, 03:06 PM   #2
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
Default Re: Pressures for normal radials
I have used a range of pressures for the rears anything from 22 to 45 psi.
Fronts 50 to 55 psi.
Good luck and have fun
Giant is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2013, 03:38 PM   #3
dieseltrain79
I found 22psi in my normal street tyres worked best . And yep 45-50psi in fronts .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2013, 05:52 PM   #4
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
What profile were your street tyres?
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2013, 10:28 AM   #5
Giant
Giant's Avatar
215 60 16
225 50 16
Old 12-09-2013, 09:54 PM   #6
dieseltrain79
Mine were 265/35/18 .
Old 12-09-2013, 11:17 PM   #7
azza11
azza11's Avatar
My street tyres are 255/60/15, i have lowered the car with reset leaves and 2” lowering blocks, for the 15’s its as low as i could go with out being a major pain.
Old 12-09-2013, 11:19 PM   #8
azza11
azza11's Avatar
Proper gearing if i wanted to optimize trap speed and revs would be 4.11’s, but would be a pain on the highway, car has 3.5’s as standard. Seen a XP sedan with 200/C4, he races the eighth and hist the limiter just before the fin line.
Old 13-09-2013, 03:24 PM   #9
dieseltrain79
Probably limiter in 2nd gear for 1/8th mile , not 3rd.
Old 14-09-2013, 09:33 PM   #10
azza11
azza11's Avatar
yeah i wish, its a 3 spd manual, will do 80 in second with stock 200 super pursuit and custom exhaust dropped, i am trying both on Sunday, got the big wheels, pipe up etc for a true street trim, then drop pipe, bolt on screamer pipe, 14’s and remove air cleaner, will get a good idea of what these changes do, bring on The Six Banger Nats
Old 15-09-2013, 06:59 AM   #11
dieseltrain79
Depends on how fast it is as to whether it will run out of legs over the 1/4 .
18's should be up to 120
17's 130
16's 140
15's 150
14's 160
Rough guidelines , but averages show , lower in the Et range closer to the speed range .
Good luck .
Old 17-09-2013, 02:50 PM   #12
azza11
azza11's Avatar
i won my class on the weekend at The Six Banger Nats at Warwick, i ended up buying 175/70/14’s, ran 25 pounds of pressure, seemed to be good, with the 3.50’s it wasn’t super fast at the fin line. Eighth mile drags, my best ET was 12.66 at 53.75, stock 46 year old bottom end, head has been off once for ULP conversion, untouched car, dizzy, custom exhaust with 2.5 inch collector and screamer pipe, no aircleaner on these runs, havent even timed the motor, seems spot on. Consistent, 8 races, no loss’s apart from
2 breakouts, car went quicker when it was around 30 odd degree’s in the sun back to back runs.
Old 19-09-2013, 04:39 PM   #13
dieseltrain79
That's awesome mate ! Well done .
