13-01-2006, 12:47 AM | #1 | ||
pat (EDXR6T) was tryin to start the car, but wouldnt crank over because it haddent been started for a while, in the garage atm, so he went to start it again but all of a sudden we see this glow from the battery, he had the dam charger hooked up to it :S
after that happened, switched her off, and the lights came on in the car, and the areal started rewinding itself, then turned the key, and everything went off, try crank it over, but nothing, then turned it off again and we heard something shorting behind the dash ( was that red box just above the handbreak, i thinks) and after it stop shorting, lights came back on and the areal went back at it. has he blown something here, its really not good, and prity worried, we have a spare red box, should we just switch it over? |
13-01-2006, 12:53 AM | #2 | ||
Last warning
check all the fuses first.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
13-01-2006, 12:54 AM | #3 | ||
Custom user title
sounds like just a looose batery terminal
13-01-2006, 12:57 AM | #4 | ||
Red box is smartlock.
13-01-2006, 12:58 AM | #5 | |||||
...i thinks hes mad a boo boo :( EDIT: Quote:
13-01-2006, 01:10 AM | #6 | ||
He hasnt got the terminals on the wrong way has he?
Blue box is the BEM, controls the electrical features. Central locking, aerial etc
13-01-2006, 01:13 AM | #7 | |||
i think it might b the BEM thats were all the noise is coming from that or the smart lock box tomoro il have to take the box's out and change them hopfully this fixis it or im not driving it on the cruize:( |
13-01-2006, 01:36 AM | #8 | ||
damn, no good Pat. It sucks when things don't go right. :( Good luck getting it fixed.
13-01-2006, 01:43 AM | #9 | |||
atleast u now wut im going thru lol and to ppl thinking its low bat noise its not it's way worse then that and it's not consisten cracle |
13-01-2006, 03:20 AM | #10 | ||
ED BEM is green, and sits next to and behind the radio. ED Smartlock is Red.
In an EF/EL, the BEM is blue. To remove the BEM in an ED, take the radio facia off, and there is one single screw top right behind the facia. Before undoing this, unplug the BEM plugs from behind the dash, unscrew the screw at the front right corner, and pull it out from under/next to the hardbrake. If funny things are happening, such as aerial, climate and trip computer lighting, dash lighting, interior lighting, etc, it's most likely the BEM, and this controls all of that. |
13-01-2006, 03:28 AM | #11 | ||
i think so too, thats were the noise is coming from anywayz
cheers mate, thx for help fellas |
13-01-2006, 03:56 AM | #12 | |||
Low series EBII and ED have a blue, one plug BEM. High series EBII/ED has a Green one with two plugs. EF/EL has three different ones.
13-01-2006, 12:11 PM | #13 | ||
Ah ok, thanks for clearing that up
13-01-2006, 12:19 PM | #14 | ||
well got fixing the prob this morning
it was still doing the same thing then i pulled the smart lock out (didnt disconected the plug just unscrewed the box) and i had it hangin i put the key to the ignition and every thing was fine tryed kicking it over starter engaged but wouldent kick over but the crakaling noise is now gone wut ive noticed tho is wen u put the key completlly off it doesent make that tick' tick' noise n e more do u recon that is stoping it from starting ? |
13-01-2006, 01:48 PM | #15 | ||
FPV GT Owner!!!
Is the fuel pump humming a few seconds before startup??
check the wires leading to the starter too.. Also, could even be your earth wires shorted.....
Cars: - Ford Ranger Wildtrak - XY GT Replica - XB Coupe Project |
13-01-2006, 03:46 PM | #16 | ||
yer fuel pumps humming
im just wandering y its not making the tick tick noise n e more n e suggestions? |
13-01-2006, 05:41 PM | #17 | ||
[EBGLT]
Switch that red box over and if its still doing it obviously thats not it.
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
13-01-2006, 06:33 PM | #18 | |||
wen i moved it it all went bk to norm well besides the fact that the engine wont start and it dont make that tick tick noise im stuped:P i gues il go to jolleys tomoro and get a fairmont BEM and try that out |
13-01-2006, 06:40 PM | #19 | ||
[EBGLT]
Sounds like a loose connection or maybe a bad earth somewhere?
