Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
Just been looking at ebay for angel eye globs that would fit an AU XR8.
Would these (or anything similar) work? http://www.ebay.com.au/itm/White-Hal...item3f290e8212 UK
Issue with that is there is no park light the globe where the XR series does. So you will have loose wires around.
You would also need to check the dimensions of lights to ensure correct fitment and will be adjustable
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
Would the angel eye be/could be the park light?
UK
