Old 13-01-2006, 05:36 PM   #1
snypereb
[EBGLT]
snypereb's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
Post 3.9 not 4.0
Sory boys in the last few days have worked out that my car is a 3.9 not a 4.0. Got a question to can you fit a ef-el mpi on this engine or will i have to get an ea-ed one?
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2006, 05:39 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
no you can fit it, i fitted the ef/el bbm etc to my ea engine.
ea to au are all the same for bolting head etc on.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2006, 05:47 PM   #3
snypereb
[EBGLT]
snypereb's Avatar
Sweet thanks mate how hard is the conversion?
[EBGLT]
Old 13-01-2006, 05:50 PM   #4
EA2BA
PM me if you want
EA2BA's Avatar
well its pretty straight forward to bolt it on, but to make it work correctly you have to add the el ecu, and thats the tricky bit due to smartlock (unless you have it already like in an ed) so it has to bypassed or added, otherwise you will need after market ECU as otherwise using a frequency switch for the bbm runners does not allow proper fuel mixture and it goes very rich in the upper end of the revs, i.e. above 3,800 rpm
I should also add if you have cruise control you will have to get creative to allow it to function as the throttle connections need to be re-done.
Old 13-01-2006, 05:55 PM   #5
snypereb
[EBGLT]
snypereb's Avatar
I just have central locking on it.
Whats bbm?
[EBGLT]
Old 13-01-2006, 05:59 PM   #6
EA2BA
PM me if you want
EA2BA's Avatar
bbm = Broad Band Manifold (the ef/el mpi manifold)
do a search on bbm* in e-series chat if you want to learn more, then post your questions you have left
Old 13-01-2006, 06:02 PM   #7
snypereb
[EBGLT]
snypereb's Avatar
Sweet thanks mate seems pretty straight forward!!!
[EBGLT]
Old 13-01-2006, 07:39 PM   #8
Damo
why did you think it was a 4.0 ? the 4.0 was introduced with the EB series 2. I would just do a normal MPI conversion if I were you. I have a manifold and injector loom you cna have for a pack of winnie blues. :P Have a few other parts you might need to.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 10:17 AM   #9
snypereb
[EBGLT]
snypereb's Avatar
Sweet mate pm me tell me what ya got. Bring that manifold and loom to the 20th cruise ill bring the winny blues!! Just always gathered it was a 4.0 then was doing some work the other day and noticed 3.9L on the front of the engine car didnt come with any books or anything so i just presumed!!
[EBGLT]
Old 14-01-2006, 10:38 AM   #10
HOON69
HOON69's Avatar
s1 eb did have 3.9L
honestly why bother with it all
i'd go buy the mpfi manifolds as stated and do that conversion BBM are easily fitted a pain to setup
i had bbm but due to the dude doing a dodgy setup etc i had it removed
back to mpfi for me easier to run n fix and do..
just go whack AU head on with EB MPFI and you'll be sweet
HOON69 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 10:59 AM   #11
snypereb
[EBGLT]
snypereb's Avatar
Sounds like a like mate!!
[EBGLT]
