Old 13-01-2006, 11:03 PM   #1
EDXR6T
Default why wont it start??
hi all
had some trouble geting the car started recently
its bin siting in the shed for about a month now(respray)
and i tryed getting it going and i wont start
the starters doing its job the fuel pump is muming at the start of
but wen i pulled the spark plug out thay r dead dry
i'v hade some electricle prob's resentlly too
would screwing around withe the smart lock moduel(pulling it out and swaping it over) affect the injecter's some how because it's getting fuel to the rail but seams it's not getting thru the injectors
n e help is greatly appretiated
cheers pat.
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2006, 11:20 PM   #2
EBFalcs
check the fuses one of the top row ones can make the car not fire when the fuel pump and stater is working.
EBFalcs is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2006, 11:25 PM   #3
Damo
have you pulled th fuel line off the rail ? check for fuel, or loosen the clamps and crank it, should get fuel squirtin out.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2006, 11:37 PM   #4
EDXR6T
all the fuse's are good chead all of them today
yer damo fuels coming out the line in to the rail unscrew'd the hose clamp a bit and it started scwerting fuel out
Old 13-01-2006, 11:39 PM   #5
EBFalcs
listen for a ticking sound from the injectors when you crank it.
Old 14-01-2006, 12:19 AM   #6
EDXR6T
yer mate il give that a shot tomoro plus
would the BEM unit have n e thing to do with the engine wiring loom??
or is it purely for intirior electrics eg. lighst's,climate controle,dash displays,all that
cheers pat.
Old 14-01-2006, 09:46 AM   #7
64compact
it will just be the ign coil it will have a small crack in it and when it was sitting it would have got some dust and moisture in it and it will be shorting out. put a new one on it and it should fix it i keep a coil handy when i do break downs as it is normanly just that, if you don't want to buy a new one borrow one to try from a mate.
64compact is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 11:46 AM   #8
snypereb
[EBGLT]
snypereb's Avatar
Are we cranking now?
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 08:38 PM   #9
-jjM-
-jjM-'s Avatar
nope not yet man
havent had n e tme to get around to trying some ideas out(painting all day:P)
but next week wen i have some time ill have a nother look and get stuck in to her
cheers guy's for ur help
p.s this isnt JJM it's EDXR6T wrong account:
-jjM- is offline   Reply With Quote Multi-Quote with this Post
