AU II XR8
Is anyone else having the same issue? Its taking me about 40 seconds to load a new page on fordforums.com.au
However, every other website I have been using is normal. Its been like this for about 2 days now. Any ideas? thanks.
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
Car needs a wash !
Same here.
Havn't noticed....
Matakana NZ
![]() Join Date: Aug 2005
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one. My Work Wagon AU Futura Wagon in Gold. On the Farm : Ford 6600 Tractor |
Yep slow here too.
Benny.
GT 335 MKII, ZF6, Tein coilovers, YT snout, 61mm pulley, KPM 1500HP fuel system, 1000cc injectors, E85, KPM exhaust, BMC air filter, KPM Streetfighter intercooler, built tail shaft, Truetrac, 479rwkw - 950nm. |
Fossil fuel consumer
![]() Join Date: Jul 2005
almost unusable here
Performance moderator
![]() Join Date: Feb 2005
dial up slow
Chairman & Administrator
We are aware of the issue and working on resolving it.
Regards Russ
Observatio Facta Rotae
Former BTIKD
![]() Join Date: Mar 2005
![]() For those that haven't viewed the other thread, Russ posted reports about this for most of yesterday. The last post was made at 12:40 am and then again at 6:15 am. So it looks like he hasn't been getting much sleep. I suggest buying shares in Coffee and Panadol as he'd be going through large amounts of both ![]()
Awesome
Location: In my own little world..Everyone here knows me :)
I will take shares in Twinings Earl Grey and English breakfast as I know Russ isn't that keen on Coffee...
![]() Is it Frustrating having it so slow? Yes...abso-bloody-lutely...all round I would say... for Russ and members alike! If anyone can get this issue sorted though, it is definitely Russ. ![]()
RIP...
Here's Russ in action...
. Oval Everywhere... |
4 users like this post: |
^^^ I always pictured Russ looking more like a mixture of Yoda and Morgan Freeman
#13 | ||
At the moment it is more like a mix of Julius Sumner Miller and the Mad Hatter.
I'm going to have to take the server down for 15 minutes to see if I can fix the issue which appears to be a deliberate denial of service attack. Cheers Russ
#14 | ||
Sorry it took longer than expected. Not sure if we have immediately resolved it but there is now something installed to block those type of attempts in a different way to the way we have been using. May take a little while before it becomes effective and it might actually block (albeit only for 10 minutes) legitimate users while we fine tune it.
Cheers Russ
#15 | ||
I'm sure you have it under control Russ, but just in case I've had a fair amount too do with DDOS, spending many weeks battling it.
Not sure how the site is hosted etc but a quick and simple (but expensive) solution is to use a commercial service such as BlackLotus. Another much cheaper but still effective service against most DDOS attacks is using a CDN such as CloudFlare for your DNS hosting. You can also purchase device such as Radwares Defencepro but they aren't cheap. Another simple trick is to change the servers ip and of course, modify the DNS (having a low TTL helps here). Many DDOS attacks go for the IP address. I use a combo of the above. Hope you get on top of it mate, it's a massive pita and most of the time, the attacks are from outside aus so you can't do much legally if you are lucky enough to trace them :( |
#16 | ||
![]() Join Date: Dec 2010
Well I was just blocked from getting on for the last hour but now am able to.
Ride 2007 Ripcurl BF Xr6 Ute Mods to Date Ceramic Coated Pacemaker 4495s 2.5" Dual Venom exhaust, Bluepower CAI Eaton True Trac with 3.9s 20% Underdrive EcoLpi Motor RWKW: 200.0 Nm: 394 Mods to Follow Supercharger |
#17 | |||
Just get a message saying the IP address is banned. ![]()
2011 FG GTP 335 S/C. Auto, tiptronic. iPV ceramic headers, stainless hi flow cats and big bore, BMC filter, X3 tune, DBA T3 rotors, Roadhouse Performance pads. From Herrod; 100lb injectors, hi flow pump, Aeroflow fuel regulator, air to water intercooler, hi boost pulley kit, JLT breather. Hub dynoed at 598fwkw, 498rwkw, 959Nm torque, boost 10.62psi at 3750rpm (warm day). All done by iPV! Other rides; '21 Jaguar F-Pace, '21 Ford Ranger FX4-MAX. |
#18 | ||
I'm going to close this thread as there is another on the same topic.
FPVS3 - it's been answered many times before but one of the methods we use to keep spammers out is to IP block the ranges they use which funnily enough are mostly overseas. A simple email to admin@ will get the block removed or the range narrowed for you. Cheers Russ
