22-06-2014, 03:26 PM | #1 | ||
Hi Guys, My daughter has broken her exterior door handle (2007 Zetec Hatch) and i was wondering how you access them? I don't want to break anything yanking on the wrong part Cheers!
Steve. Last edited by SJG351; 22-06-2014 at 03:29 PM. Reason: model update |
22-06-2014, 04:35 PM | #2 | ||
I suspect you need to get at it from inside the door usually a couple of nuts holding it to the inside door skin. what I cannot recall is oif you have to remove the "plate" covering the electric window mechanism. It covers most of the inside door panel under the exterior plastic trim
22-06-2014, 05:00 PM | #3 | ||
when you open the door there is a black bung level with the handle. pop that out and theres a torx screw. undo the screw and the outer handle comes off
23-06-2014, 11:10 AM | #4 | ||
Guys, Do i need to remove the door trim and if so how?
Steve. |
23-06-2014, 11:15 AM | #5 | ||
No door trim stays on I will attach a pic later if needed but just look for oval shaped black bung inside door level with handle juat above the latch
23-06-2014, 11:26 AM | #6 | ||
