26-01-2006, 09:55 PM | #1 | ||
Hey
I amm getting my exhaust made up for my EF TURBO.. Its off the turbo dump pipe, down to the CAT, then CAT out to the back of the car.. The thing is that I can get it made OVER the diff (stock path).. or get it made UNDER the diff.. But im not sure if it will be okay under the diff.. will it scrape? or hit the diff? I prefer to get it made under the diff, cheaper and easier to install, and it has to flow way better than the over the diff setup!.. BUT I dont want it scraping and rattling and all that shiiitt.. Would like to know if anyones done it, or any theories on it.. Thank you -jkk |
26-01-2006, 10:00 PM | #2 | ||
Last warning
There was a member on here that had one.
it may have been EB 6 on boost. i recall he sold it to upgrade. clearance would be a major issue. personally i'd go over the diff to safe all those hassles.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
26-01-2006, 10:13 PM | #3 | |||
yeah clearance may be an issue, any idea how much lower it would sit? might just have to go over the diff thank you -jkk |
26-01-2006, 10:14 PM | #4 | ||
eb six on boost
got it!! thanks |
26-01-2006, 10:24 PM | #5 | ||
Last warning
check the height of ur diff as it is at the moment, see what actual clearance you have.
then consider you'll have 3" diametre pipe under it, with a gap to ensure the diff doesn't knock the exhaust.
26-01-2006, 10:27 PM | #6 | |||
doesnt sound good as the car is like about 110mm off the ground at the moment.. -jkk |
27-01-2006, 07:50 AM | #7 | |||
Not your average EF Wagon
Go over the diff, it really does not matter, just as long you have 3" dump pipe of the Turbo, high flow cat and 3" all the way through. You may require 1 muffler to quiet the thing down a bit.
Power by HeadTech Performance Williamstown The recently SOLD 95 EF Wagon 5spd NA SLEEPER The Daily cruisers now *95 R33 Skyline GTS-T RB25DET *93 Lexus GS300 2JZ-GTE Car enthusiasts visit Unique Cars and Parts
27-01-2006, 09:27 AM | #8 | ||
Dump it before the diff, problem solved.
27-01-2006, 09:47 AM | #9 | ||
Go over the diff, plenty of people are making power with the exhaust in the right spot.
Your mufflers will be the main cause of restriction anyway.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
27-01-2006, 09:52 AM | #10 | ||
Former E-Series Member
There was a guy named Kyle Hopf who fitted a 4" exhaust over the diff in an EA.
27-01-2006, 02:50 PM | #11 | |||
Sundeep |
27-01-2006, 06:05 PM | #12 | |||
haha your the biggest random! |
27-01-2006, 06:08 PM | #13 | |||
thanks for all the replies guys
i talked to EB SIX ON BOOST and he said that he ran it under the diff for a long time and never had any problem with it at all.. and recommends doing it.. Quote:
im just going 3inch turbo back with a high flow CAT and a twin tip.. -jkk |
28-01-2006, 03:02 AM | #14 | |||
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
28-01-2006, 12:49 PM | #15 | |||
obviously! has to be suited to street use! haha :nutsycuck -jkk |
28-01-2006, 05:25 PM | #16 | |||
Sundeep |
28-01-2006, 05:34 PM | #17 | ||
Engineering ИИИИ easy, I dont see any reason you shouldnt in Vic.
haha :P
28-01-2006, 06:50 PM | #18 | |||
you ИИИИs are trippen!!.. : |
