03-07-2014, 03:10 PM | #1 | ||
Occasional V8 user...
Hopefully, I have the terminology right...
I have an AU2 V8 Falcon Ute, which has had a 3.9 ratio LSD installed. As a result, the speedo (and odo/trip meters) read "fast"; the speedo by ~20KPH at all speeds... Short of sourcing a 3.45 ratio diff to restore speedo accuracy, the other option was to replace the transducer with one "geared" for a 3.9 ratio diff. Problem is that the biggest on Ford stocks is a 23-tooth version (original was 22 teeth), so the correction has meant that the speedo still over-reads by 10KPH through the range. Question is, does anyone know of transducer units compatible with the T5 gearbox which may have been sold in the US or UK (for example) that are 24 teeth (which will restore the speedo to near-accuracy)? Or, does anyone know where I might find that information? Thanks in advance for any/all assistance. Michael
Is it an AU Ute that thinks it's a Fairlane, or an AU Fairlane that thinks it's a Ute? |
03-07-2014, 05:58 PM | #2 | ||
You will need to fit a "Speedo Corrector". A little electronic box that splices in to the sender wire to the speedo and allows you to adjust it.
I bought one a long time ago but never got around to fitting it before I sold the car (had 4.11 diff in the AU). Not sure what they are worth now, mine was $50 fully assembled.
03-07-2014, 06:07 PM | #3 | ||
Thanks mate, sounds like the GO. Will have a hunt around for one. Cheers.
03-07-2014, 06:14 PM | #4 | |||
Just as an aside, do you remember where you got your from? There are a sh*tload of (what look like) bike-specific ones out there, but not many for cars...(Do you still have yours, perchance?)
04-07-2014, 10:55 AM | #5 | ||
Yeah, I still have mine stashed away still in the original bubble wrap packaging. If you want it PM me and we can sort something out I'm sure.
04-07-2014, 11:21 AM | #6 | ||
5.6L x 2 pilot
Hi Michael. I am pretty sure Jaycar sell them. Good luck.
Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
04-07-2014, 05:39 PM | #7 | ||
FG XR50 TURBO
