Old 22-11-2015, 04:00 PM   #1
raised by monkeys
raised by monkeys's Avatar
Default Open day hacker - looking for some advice
I'm entering in a local 1/8 drag day in BF F6 Tornado. It's got factory suspension with a few mods and tuned at 327rw wasps, and has factory 6spd man/clutch. I've picked up some TOYO R888's. Has anyone used them before?
I couldn't find the info on the TOYO site but i want to know approx. what PSI should i be running i them.
Do i have to do a big burnout to generate enough heat? Im not overly experienced in doing burnouts so not overly confident, but enough to spin the tyres a little.
Any hints or tips would be greatly appreciated.
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
Old 22-11-2015, 07:32 PM   #2
FLOGGED
FLOGGED's Avatar
Default Re: Open day hacker - looking for some advice
What tire size you running?
Depends, give it a quick spin to get any rubbish off the tires first time, if it doesn't hook too well try warming them up a bit. Don't go trying to do a massive burnout as you will heat the tires up too much.
If you have the chance to do quite a few runs i would be playing with tire pressures, if your still spinning try putting them down a few PSI.
Also try launching at about 2500 RPM to start off with and if there is no wheel spin keep bring your RPM up. Remember the key to a quick 1/8th time is a good 60ft time.
Not the best info, sure someone could give you alot more helpful tips. I drag race ALOT but kind of different as mines auto, i just do quick burnout stall & launch, easy.
"If Everything Seems Under Control, You're Not Going Fast Enough" - Mario Andretti
2009 Fg Xr6 Sedan n/a 5 Speed Auto - 14.1 @99 MPH
Mods: Redback Exhaust & Cold Air Intake
Untuned
FLOGGED is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2015, 11:47 PM   #3
raised by monkeys
245/40r18
cheers
Shaun
Current
Previous
Old 23-11-2015, 02:25 PM   #4
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Small skid and 25psi IMHO
Have fun Shaun...
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2015, 02:36 PM   #5
raised by monkeys
thanks dude
cheers
Shaun
Current
Previous
