#1 | |||
Are you using the cig outlet or USB to power the cam? What brand/model of cam? Has anyone bothered connecting an OBD2 port wifi/Bluetooth adapter? I have one that I used on my previous car, but haven't got around to trying it on the Focus yet. They can be useful to check various readings that aren't normally visible. Eg. Coolant temp, battery voltage, loads of sensors etc. You need an iPhone or android app to display and potentially read/reset codes.
2009 Ford Fiesta econetic - silver (sold 2012) 2012 Mazda6 Touring Wagon - silver (sold 2015) 2015 Ford Focus LZ Titanium - Magnetic (sold 2019) 2018 Ford Focus SA Titanium - white (current) |
#2 | |||
Using two added circuits on the fuse box under the glove box. One circuit is 24/7 battery and one circuit for ignition. It is designed to turn off power to the cam at 12V and turn back on when the ignition is on. As far as I am aware it has not reached 12 volts, so the camera has never turned off. |
#3 | |||
Still have to work out where to install it. Was going to go in the center under the rear view mirror but noticed the wipers don't cover that area and I'd prefer not to have it too low. I'll figure all that out when it arrives ![]() |
#4 | |||
11.5v is the only other option if I remember correctly. 12v is way too low for a battery.
That is how I had done it. You can buy these "Add on Circuits" for the fuse box. Goes in like a fuse, you place the original fuse into the first slot, and then you have a fuse slot for the added circuit and a good bit of wire to start from. For the Ground there is a 10mm nut behind the fuse box, just use a ring terminal. |
Thanks for the pic. Yeap, I'll be using a fuse tap, just the one though. When you say you've used a ground nut behind the fuse box, does that mean you've removed the fuse box? Just looks a bit tight in there so I was hoping that wouldn't be needed.
#6 | ||||
From what I can tell the killer of fuel is uphill and slow moving traffic. If you can set and forget the cruise control to a speed then you are going to save fuel. Tho that's a given. When you do drive it fast using higher revs and a lot of throttle in corners, you don't use much more fuel. 8.538L/100Km was Putty Road. Although the driving score was very low after that. |
