Old 28-11-2016, 11:02 AM   #1
Shaiyanna
Default 2008 Ford Focus Clicking Noise
I have a 2008 Ford Focus hatch. 120,000 km. Great condition, at least cosmetically. I've done nothing but spend money on it in the 3 months I've owned it. Some basic maintenance, but some unexpected. A couple of weeks ago I replaced the plugs only to find pot #4 full of oil after I pulled the coil pack off. Seems a new valve cover gasket has fixed it, but we'll see. Transmission has been serviced, but is still stuffed - slips when cold and sluggish when warm - but it'll have to do for a while longer, a rebuild is something I can't afford so close to Xmas. I have replaced the brakes all round, including new rotors.
The clicking noise though. Sounds like a playing card on a spoke, speeds up as the car speeds up. I replaced the rear passenger wheel bearing - in fact the whole hub - with a new one. It hasn't stopped the clicking noise though. Definitely coming from the rear passenger wheel but I'm stumped as to what's causing it. New wheel bearing, new rotor, new brake pads - where do I look now? (Incidentally it was worse when it was wet).
Shaiyanna is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2016, 12:21 PM   #2
DZFord
DZFord's Avatar
Default Re: 2008 Ford Focus Clicking Noise
Have you tried lifting the rear of the car up, hand brake off, spinning the right rear wheel and then trying to isolate the noise?
Old 04-12-2016, 02:40 PM   #3
quankino
Having same problems on my 2008 FF Hatch 150k km. I'm thinking about taking it to Ford dealer to do full services
quankino is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2016, 02:51 PM   #4
Shaiyanna
Can't for the life of me find anything loose, and it didn't do it when we had the wheel off. Only does it when you drive.
Old 05-12-2016, 04:47 PM   #5
marg99
Left field but I had a retaining ring inside the plastic wheel insert come loose once and it may a clicking noise when rotating the wheel Only found it when I removed the wheel
