Car has been running rough, and recently threw a P0171 code, so I decided to clean the O2 sensors. Currently have the sensors soaked in petrol.
When I put them back in, do I need to use grease / anti seize on the threads? If so, can I use any old grease or does it have to be a specific kind? |
#2 | |||
You can't stop the signal
Anti-seize.
New sensors generally come with this already on the threads. Helps removing them after heat cycling
My new 02 sensors came with grease but I can't help on what type it was.
Gen Y Falcon nut
copper grease is usually the go
BA XR8, Boss 315, T56, Herrod Cams, BPR CAI, X-Force head to tail, |
Anti seize or copper grease. Super Cheap has anti seize for under $10 a tube.
Thanks. I'll have to pick some up tomorrow and re-apply it.
Damn...the car idles perfectly now, and the way it accelerates is way smoother. Not sure if it is due to the O2 sensor clean, or whether because the temp is cooler and the tune is adjusting. The last week, which has been hot and humid in Melb, it was spluttering and coughing at idle. Have also cleared the DTC so will see if P0171 comes back. |
