I feel silly asking this question, but bear with me...
The radiator cap on my AUII XR6 looks original and fairly worn out. Went to buy a new one, but no one (Repco, SCA, Autobarn, eBay) stocks a 120kpa / 17 psi replacement, only 135kpa / 20psi. With radiator hoses possibly approaching 17 years old, I'm a little hesitant using one with a higher pressure. The only alternative I can see is the Tridon CN15100, which is 100kpa/15psi. Any recommendations? ![]() |
Missing a sock...
![]() ![]() Join Date: Mar 2012
I looked up the Tridon and CPC catalogues - they only list the 20psi caps. If your cooling system is in good order, this doesn't present a problem.
I can't comment on going to a lower psi cap, so I won't. If your hoses are 17yo, then you've got a good run out of them. A lower psi cap is not going to save your ***. Yes, it's a PITA changing out all the hoses, but best be planned at home to do it. Imagine if one of the hoses blows while out on the road and the inconvenience it would cause - let alone the cost of towing fees. Replace the hoses now mate, that's the best advice I can give you. Cheers! Edit: Flush the cooling system and add rust inhibitor/coolant while your at it - your alloy cylinder head is expensive to replace, if it's not already munted.
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
Good advice, but I'd still rather use a radiator cap that is equivalent pressure to the factory cap.
#4 | |||
🚫⏰4️⃣🐃💩
Going with your theory, have the tyres being replaced with the original spec tyres? Or the brake pads with the exact same spec as it came from factory? |
3 users like this post: |
3 PSI is bugger all - old age hoses, well, that's another thing.
RIP...
It's not a good idea to increase the pressure of the radiator cap over standard, the system may not be able to handle the increased pressure.
However, AU2/3 spec is 15-20psi, so you'll be ok. Your hoses may still be fine, if in doubt, replace them too.
. Oval Everywhere... |
RIP...
The Tridon catalogue has caps listed from 7psi to 20psi (and everything in between) to fit an AU.
2 users like this post: |
Buy a genuine Ford one.
#9 | ||||
Will do, if I can get to the spare parts counter before they close. I'm not actually chasing an issue here, just replacing a worn looking cap. Don't want to create a problem unnecessarily. |
HSV - I just ate one!
IIRC VY V8 commodores have a 120kpa cap
