#31 | ||
Ford Fanatic
Wynns do a Smoke stop, Engine Tune Up, Stop leak,Power steering treatment, Radiator stop leak etc.
Truly amazing what a bottle of additive will do, However I won't be impressed until they come up with Liquid ConRods for a broken Conrod.
Everyone is entitled to my Opinion ![]() 2007 Territory TX SY RWD Ego |
#32 | |||
SMOKE STOP.. try rebuilding your engine.. ENGINE TUNE UP... try a real tune up.. STOP LEAK.. try replacing leaky gaskets.. POWER STEERING TREATMENT.. half a cup of thinners.. RADIATOR STOP LEAK... pepper it works.. hahha ha ha LMAO.... Daaannnggg... SNAKE OIL THE LOT OF IT.. Pottery |
#33 | ||
My old cheap ebay 2ltr pinto engine just last week was blowing smoke badly on idle and reving ,was going to the all ford day the next day so I poured a bottle of stop smoke in it at the servo 5ks from home and its was like a new engine by the time I got home.
So mister pottery you may want to give it a try,this isnt the first time Ive used it in an emergengy. As well as noisey lifter stop worked on our old au ghia.
T2 TE50 no:154 Narooma blue AU2 XR8 ute XR4 fiesta |
#34 | |||
Bushbasher Re: Roil - IMO, if this stuff is as good as it appears then the question of cost v savings becomes the issue I think. If it has to be added at every oil change then it effectively doubles the cost of that oil change. You'd have to make significant fuel economy savings to make it worth while or it just becomes a false economy considering a well serviced modern engine will go 500,000km easily if looked after properly. I've emailed the distributor and asked this very question so we'll see what he says. If it's something that only needs to go in every 50,000km ( lets say) then it would be good value but if it needs to go in at every change then unless your engine has some issue to start with, why would you bother. I'll keep you all posted and let you know what the distributor has to say. i can`t remember word for word Bushbasher but the distributor i spoke to mentioned this he said add approx 70 ml per litre first oil change then next oil change add a much smaller amount (had it written down lost in my good filing system), will be interested what your guy says. Last edited by mik; 06-06-2009 at 09:21 PM. Reason: alziemers :( |
#35 | ||
I agree about regular oil and filter changes is all you need. I reckon a lot of the taxis in melb just do this and probably get 500 000kms+ out of their engines.
But, if you see results like fuel economy from oil additives then go ahead and use it. I think the oil/additives you use today are far greater then the dinosaur oil used 20 years ago. I reckon the cheap $14.95 4L bottle of oil would be fine. Just regular maintenance far outweighs the oil you use I reckon. |
#36 | ||
When in doubt, GAS IT!!
For Mik and anyone else who's interested re. the Roil metal conditioner; I got a reply from the distributor and he basically said full dose first time then half doses every change after that. He also claimed a 10-15% fuel economy improvement .
If his claim is anywhere near accurate then at a half dose at say 10000km services then considering all the other benifits, ie. cooler running, less wear on cold start, more HP etc. it would seem like a worthwhile and cost effective excersize. Keep us posted Mik on how the stuff goes for you, expecially your fuel consumption. Anything that can boost your HP and improve your economy while protecting your internals has got to be worth a look I recon. Bushbasher
#37 | |||
By all means if you use these miracles in a bottle and get results good luck to you especially if its gona stop a canary.. I just see them as a temporary fix masking a bigger problem.. IMO if ya motors stuffed.. its STUFFED.. Pottery |
#38 | ||
i have used nulon engine treatment for years.i use it in my daily driver and in all of my cars and it has never blown gaskets or done anything wrong to any engines i have put it in.i have noticed they run smoother and cooler etc etc and the results are instant especially when you put it in the the engine warm and running.but i can only go off my own personal experiences not something i have heard second hand.i think they work excellent and will always use them and my daily driver still doesnt burn oil.
#39 | |||
#40 | ||
roil update
#41 | ||
update: for what ever reason my last post i mentioned after a week or 2 with the roil in fresh oil i had noticed while doing a day trip after having lunch with the relo`s and starting the run home, i i did a James Bond smoke screen on a full power take off to get into a break in the highway traffic
![]() ![]() OK by the speedo did 388 K`s travelled at the end of the run still had 519 dte on the dash, total k`s =857, as noted 1/2 hour up an down a dirt track (corrugations 2k`s+ large potholes approx 1/2 a k ) add to that had to do a u turn and back track 100 metres for missed toilet stop for the other old pensioner, i also deducted 6% of kilometres traveled for speedo/odometer error, that adds up to 805 k`s theoretically traveled in total, i used the economy calculator http://beno.id.au/html/webpages-goldwing/ecoCalc.html ... it gave me 7.45 litres per 100 k or in the old scale for us oldies 37.88 mpg.....and i screwed up on the way back to melb i missed the turn that takes you all the way in to town so had to deal with the traffic heading in from ford factory inwards. All in all a pretty decent figure for an xr6 i think, i would say i`m better off by at least 50 k`s per tank, perhaps a little more on a trip, if my last run to geelong was any indication it would be closer to 80/100 k`s better( but that might be a freak conditions were perfect) since the roil additive, there you go i`m not saying the stuffs good or bad just reporting my findings, some might say thats not exceptional economy for an Au but for mine it is definatly a little better than usual. |
#42 | ||
metal conditioner
hello all
i have previous talk about the advantages of roil gold and it is great to see the results of your xr6 !! this product works in engines gearbox ( a/t and m/t ) diffs and powersteering ! so if you need to get the same results as mik has .. pm me and there is a special price for ford forum members
if you use oil .. you need roil ?? www.roilgold.com.au the metal conditioner |
#43 | ||
Starter Motor ?
Can you PM me your special price please ?
09 Ford Focus LV XR5 |
#44 | ||
metal conditioner
i have pm you
#45 | |||
XP Coupe
One of the things I do a fair bit of is to build engines. One of the processes I employ is to pour Lucas oil conditioner all over the valve train and crank prior to sealing it all up. That is in addition to the various moly greasing and molykoting. Seems to work very well. |
#46 | ||
metal conditioner
hello members
here is some links for more information http://www.performance-oil-australia.../qut-tests.htm http://www.performance-oil-australia...ut-tests-2.htm i hope this helps
#47 | ||
Nulon gear treatment fixed my diff noise
#48 | ||
I have used Moreys Stabiliser in my older cars that used to run old mineral based oils.
But these days if ur running a semi synthetic or full synthetic oil in a modern car engine u really should'nt need any additives as Synthetic are far better than mineral oils. I run full synthetic 10W50 Penrite in my Barra as recommended buy local parts shop in their Penrite book (6 litres of oil and a 'Cooper' filter costs me $80) but i am also a fan of Nulon products as their also Oz made. |
