Old 26-10-2007, 10:24 PM   #1
ecksar 6
Default au series 1 and 2/3 difference
any1 ere know why series 2/3 body parts wont fit on series 1 au falcons? it would obviously have something to do with the general structure and/or hows its mounted, but any1 know exactly what?
ecksar 6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2007, 10:26 PM   #2
Smoke Pursuit
What do u mean, all parts are carry over between the models, theres just different parts for different levels, eg Fairmont has different bonnet to XR, but they both fit providing you have the front bar and headlights to match. The doors, roof / rear / guards are the same, its just the front.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2024.50 Mustang GT 10A Grabber Blue Nite Pony Package. Due Aug 24.
Old 26-10-2007, 10:46 PM   #3
The Monty
Just slidin'
The Monty's Avatar
Everything should fit bar the brakes, and some of the suspension parts, and obviously some dash switches and stuff, but trims, panels and everything else was the same.
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2007, 07:53 AM   #4
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
The Engine Electronics were different as AU1 used gear from the EL, where the AUII used new stuff. The brakes were EL and smaller than AUII. The Bonnet and Grill (several times) were different, and front bar on the XR's.
Just the Electronics and brakes would be enough to stop ma considering a SerI. The major changes to SerIII were cosmetic, really refining what was a pretty good package.
SerIII got clear side indicators, Side skirts, ABS, colour coded mirrors, all standard, as well as better firewall paneling to dampen engine noises into the cabin.
All panels are interchangeable model to model. Even the brakes are, if changed as a unit. (You can't put SerII rotors with SerI callipers.
What prompted your question???
Mike
MNM96 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2007, 04:59 PM   #5
LeadFoot81
_Oo===oO_
LeadFoot81's Avatar
Laminated steel firewall was added from series 2 onwards.
LeadFoot81 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2007, 05:18 PM   #6
The Monty
Just slidin'
The Monty's Avatar
The stuff that was all just mentioned is all available (bar brakes) on higher spec model. Ie, the fairmont has ABS, Cruise, "high" series bonnet, clear indicators, and what people always refer to as series 2 tail lights, but if people looked, it was available on series ones.
Old 05-11-2007, 12:30 PM   #7
Cespenar
Huh?
Default AU1 brakes?
Hi Monty, (If you get to read this)
I have a 1/99 au Ghia.
All the brake upgrades seem to be an expensive change to with stubs etc.
Is it possible to put twin pot calipers on the series one, or do I have to do a complete upgrade. (about $1200)
Regards from Mike.
Cespenar is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2007, 12:53 PM   #8
FGII-XR6
FGII-XR6's Avatar
and the electronics the S2 got the smartshield immobiliser and the BEM/ECU combination is different. it is not just a matter of changing callipers and rotors either you need to change stub axles lower control arms and stabiliser bar to upgrade the brakes
Old 05-11-2007, 03:14 PM   #9
The Monty
Just slidin'
The Monty's Avatar
It is a pretty full on job, I just use dba slotteds and bendix pads, and although it stops "ok" its not the best, and they are constantly warping.
Old 05-11-2007, 04:12 PM   #10
sly
Sly like a G6
sly's Avatar
Smartshield was introduced as a running change to Series 1 production in May 1999, IIRC the same time that power front windows and height-adjustable seatbelts were made standard in the Forte. Series 1 cars thus fitted have a "Smartshield" sticker in the fixed pane of the rear passenger's door.
Some members have upgraded their brakes using the original lower control arms drilled to accept an EB sway bar (still need to change stub axles), info is in the "BA Brakes onto AU" sticky. Another option (rare) is to pick up Premium series 1 front rotors & calipers, someone had a set on ebay a couple of months ago. These will fit onto the s1 suspension.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2007, 08:00 PM   #11
FGII-XR6
FGII-XR6's Avatar
Do they wear a striped apron when they do it sounds a bit rough to me especially when the AU2 parts bolt straight up
Old 05-11-2007, 08:05 PM   #12
StealthAu
so does the eb swaybar
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2007, 10:05 PM   #13
sly
Sly like a G6
sly's Avatar
Any parts left over get made into sausages :
Sleeper, anyone?
Old 06-11-2007, 11:31 PM   #14
fourl6
AU Falcon Man
fourl6's Avatar
correct me if im wrong but i didn't think the xr series 1 rear bar add on thing (apron) fits on S2,3 rear bars
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2007, 03:43 PM   #15
Cespenar
Huh?
Unhappy
Regards from Mike.
Don't worry. I already found out. :
Old 08-11-2007, 04:00 PM   #16
FGII-XR6
FGII-XR6's Avatar
well they say iron in the diet is essential
Old 04-04-2018, 11:30 PM   #17
AUXR6WAGON
Default Re: au series 1 and 2/3 difference
Mike
Gday, sorry to open an old thread up. Just wondering if 12 slotters will fit on a series 1?
Sent from my SM-A520F using Tapatalk
AUXR6WAGON is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2018, 12:43 AM   #18
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Hi & welcome to AFF! The old school 12 slot mags? Nope afaik, i could be wrong but different offset unfortunately.
cheers, Maka
Old 05-04-2018, 12:58 AM   #19
AUXR6WAGON
cheers, Maka
This is my mates one here..
Old 05-04-2018, 01:01 AM   #20
Maka
Maka's Avatar
Yeah nice Futura, i used to have one lol. Are those mags chaser style stock wheels or proper old school 12 slotters?
cheers, Maka
Old 05-04-2018, 01:06 AM   #21
AUXR6WAGON
cheers, Maka
He reckons they're slotters. Apparently au series 1 brakes are smaller?
