Bring on the lion...
Hi all, my old man has a AU1 fairmont auto, done about 90,000ks. When taking off it feels like its going to stall and sometimes does. What could be causing this to happen as its a pain in the ***.
El falcon, 4.0, XR6 camshaft, pacemaker extractors, 2.5 inch exhaust with tri flow sports muffler, AU TE50 intake, with K&N panel filter, Advanti racing Stalker 17" rims, Sitting on Ultra Low King Springs, 'Gabriel' Ultras Lowered struts, NOW MANUAL, 3.45 LSD 9.694 @ 75.38 MPH at Mildura Drag Strip 1/8 Mile XC Falcon project car underway...... |
My 1st set of Wings!!!
G'day mate,
I wish I knew lol that's why I joined the forums to help broaden my knowledge try posting here you might have better luck than posting in the AU Workshop Build, there's also a couple of members who have posted the same problems so you might get what your after. Good luck :hihi:
PROUD OWNER NAROOMA BLUE 2002 AUIII XR6 :sm_headba |
Fantastic Plastic
check the obvious first ... leads , spark plugs , fuel filter /sender , gee even the injectors might be a bit blocked or crap fuel or water in tank , could be anything of the above or more , need to be a bit more percific , heaps of stuff discussed on this topic anyway , search the forums , gl ;)
cheers dude. ummm, leads have been replaced, plugs also, same with fuel filter, and we also ran some injecter cleaner through it. could the fuel filter be clogged as on idle there isnt as much pressure?
