Old 13-11-2020, 11:08 AM   #1
prydey
Rob
prydey's Avatar
Default 2006 LS focus, wup wup wup sound front left.
Wife mentioned this new noise yesterday. I jumped in this morning to drop my daughter to school and there is a wup wup wup sound from the front left (i think) which does increase in rhythm with car speed.
What i found though, was that it was only there for the first few minutes before eventually fading away. School is only about 5km away and by the time i was on the return journey it had gone. Well, it had become inaudible from the cabin anyway.
I was thinking wheel bearing but this is normally more constant and grumbly sounding i thought.
There is no vibration associated with it, so its not like a flat spot on a tyre from sitting around. Car gets driven everyday as well.
any ideas?
UA2 TREND 4WD BI TURBO
Old 13-11-2020, 11:10 AM   #2
raceteam
Default Re: 2006 LS focus, wup wup wup sound front left.
Could be a failed belt on a tire or some other internal failure. Just swap it to a different corner of the car and see if the sound moves.
raceteam is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2020, 11:53 AM   #3
raceteam
To add, tyre noise can change with temp as they warm and soften so if it's only there for the first few minutes of a drive, it does point to tyre.
What about swerving (carefully!) from side to side to load and unload the wheel bearings?
I've also had a flat spot (caused by a brake lock) on the inner side of a front tyre that made a wup wup sound, but only when that tyre was unloaded in a turn to that side. Under normal or increased load it made no sound.
Old 13-11-2020, 12:40 PM   #4
CatonaPC©
Check your tyre pressures, especially if the sound returns. Only one other explanation and something was stuck to the car and now no longer is.
CatonaPC© is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2020, 12:50 PM   #5
marg99
they also make noises when you get stones caught in the tread although that is failry regular sound
Old 13-11-2020, 12:56 PM   #6
prydey
Rob
prydey's Avatar
Thanks for the suggestions. I just spoke to the wife and when she mentioned a noise yesterday I assumed it was the noise I heard today, but apparently she heard more of a ticking sound. Just driving along, not just while turning etc.
More investigation required but certainly pointing to just being something on the tyre rather than a mechanical issue like cv or bearing.
Might have a bit more of a play tomorrow.
Old 13-11-2020, 02:12 PM   #7
raised by monkeys
raised by monkeys's Avatar
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
