Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
#391 | ||
#392 | ||
yep, ill grab it. please PM the total and payment details postage to 2142
Many Thanks 2001 AUII Factory LPG Manual XL Styleside Box High series bonnet Clear Side Indicator K&N Air Filter BAXR6T Snorkle Low Fronts, Super Low Leafs |
#393 | |||
![]() Join Date: Oct 2006
Give this:
regards Blue |
#394 | ||
The stone guards protector tray under the front bumper am missing mine off my au2 xr8. Are they the same across all seriers au xr's cheers
2001 AU2 220 XR8 - Build thread |
#395 | |||
How ever the high pressure hose is different between FG1 and FG2 (only talking 6 here). FG1 has two hoses one for NA and one for turbo. FG2 has one totally different hose for all 6 applications. Sorry but I don't know the exact differences are???? FG1 Set Up: FG1 Power Steering.JPG FG2 Set Up: FG2 Power Steering.JPG |
#396 | ||
2 users like this post: |
#397 | ||
Hmm; looking at pics on ebay https://www.ebay.com.au/itm/28270248...4AAOSwmj5ehfe4 the MKII high pressure lines appear to come fitted with a green O ring per https://www.globaloring.com/oring-colors/ . It seems the only way to get them may be to buy the whole high pressure line. But green O rings are usually Viton and I have a whole boxed assortment of green Viton O rings so I might try those. Only issue is this I have an aftermarket Kelpro one that has a black O ring supplied (probably Nitrile). I bought the Kelpro although it was more expensive than the genuien Ford one as I also have a leak at the loop and I thought the extra support bracket on the loop that the Kelpro has might prevent vibration and further leaks. The high pressure switch that it common to the MK I and MK Ii appears to use a green viton seal too per https://www.ebay.com.au/itm/23177128...UAAOSwbBxgdl-Y so that suggests a Viton seal should be OK using either fluid. Of course the change in fluid specs might meet that there has also been confusion over the correct O Ring material and I am going to be stuffed whatever I do.
regards Blue |
#398 | ||
The O ring is also referred to in the MKII Workshop Manual supplement at section 211-02-15. I'll PM you re buying some O ring seal part number 388898S to both use and test. Currently I am testing three different type of O rings of different materials in the new approved ATF and they all seem to harden with immersion; well at least they are not turning to mush. I will test them in the Formula F too for comparison.
regards Blue Last edited by aussiblue; 08-08-2021 at 04:30 PM. |
#399 | ||
Sprinting Everywhere!
Just wanted to find out how much front and rear mudflaps would be for a 2020 ford escape vignale, can supply vin number if needed. Cheers mate!
#400 | |||
Vignale is same as ST Line if you needed to know.. |
#401 | ||
#402 | ||
hey GT, can you buy the clips for the cover that go in the center of the dash on a FG G6E?
#403 | |||
You going to be a bit more specific than that, a picture of the clip and the part it goes on may help.. If your referring to the center cover as shown below, the clips are not sold separately, but I would need to see the clip to see if they are available from another component. FG Dash.JPG |
#404 | ||
thanks np, it is that cover. I will try a pick and pay less after lock down
#405 | ||
Hi GT
Can you still buy the FPV badge for the centre of steering wheel for a 2012 FPV GT MK11 Thanks |
#406 | |||
That badge was never available as a single part on its own (child part), to get it you have to buy the whole air bag. There are people making reproduction ones like below but I dont think they are exact like the OE ones. https://www.ebay.com.au/itm/17408652...kAAOSwKrhVbYXE GT |
#407 | ||
G'day GTLegend,
Would you by any chance have the part number for the vacuum hose that runs from the fuel regulator to the back of the engine for a 04 BA Falcon 5.4L 3v (Barra 220)? And do you have any in stock? and if so, price? Thanks.
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. ![]() |
#408 | |||
Vacuum line that goes from fuel reg to lower manifold on a 24V 3V has a part number 3R2Z9E498BA. Obsolete from Ford but I may be able to source you one. Last I remember they were around the $90 mark. If you want me to chase let me know.. GT |
#409 | ||
![]() Join Date: Nov 2007
hello.
looking for just the rear boot lid upper chrome garnish for B series fairmont. Not the whole fake light garnish as on the ghia. (already have one of them). Just the garnish the number plate lights go into. TIA
FGII XR6 IN LIGHTNING STRIKE R52 SIII IN GUN METALLIC |
#410 | ||
hmmm boost
*Re: Genuine Ford Parts Quote: Originally Posted by*GTLEGEND* Hi, Set of rear door glass hinges would be $250 including freight, how ever there is only RHS available at this point in time, the LHS wont be available until April/May next year due to the COVID lockdown where the manufacturer has been closed all this time. Any update on these ?
EL TURBO GHIA GT3582R WOLF3D TUNED BY JEM |
#411 | |||
These are currently getting manufactured, should be available in a few weeks if COVID does not interfere again. Will advise when they are available and if the costs have changed. GT |
#412 | |||
BA Boot Lid Garnish.PNG |
#413 | ||
Hi, are there any pairs of ER18494A floating around or are the NLA?
#414 | ||
#415 | ||
Ok O ring part 388898S has arrived and appears to be made of hard nylon rather than soft silicon or Viton and is much larger in circumference than the ones need on the MK II FG's high pressure steering hose. They are the white ones in the attached picture. The black one is the one that was supplied with the Kelpro hose I bought and appears to be silicon rubber. The green one is a Viton one like the ones on the genuine Ford hose. My local Ford dealer said you have to buy the whole hose to get the O-Ring (and they wanted $450.00 for it compared to $270.00 from most Ford dealers that are on ebay) but they at least were prepared to show me the packaged hose so I could see the O-ring. I am recovering from a hernia repair and other minor surgery at the moment but once I am able I will fit the green Viton 0-Ring and report back.
In any event thanks again GTLegend for all your help; I will doubtless eventually also find a use for the white plastic O rings (perhaps if I need to help someone with a Mark I FG). From past experience I have to say you can never have too many spare O-rings.
regards Blue |
#416 | ||
Hi gt,
Any chance ford still sell the ba/bf rear air vent cover, cupholder, manual gear surround and dual zone icc cover? All silver coloured Sent from my iPhone using Tapatalk
2005 BA MkII XR6 Silhouette - SOLD 2007 BF GT Cobra 6 spd manual #43- SOLD 2016 Mustang GT - Current 2010 XR6 Turbo 50th Anniversary - Sold 2006 BF MKII XR6 Turbo Seduce - Sold 2006 BF MKI F6 Typhoon Toxic - Current |
#417 | |||
If you referring to the rear console air vent louvre in satin aluminium like a BA GT, then no no longer available. Possibly get graphite one from XR, Dark Stone (Futura) only. Cup Holder: Cannot get the GT aluminium finish, but could possibly get the XR liquid metal colour one, Futura Warm Charcoal one, XR Graphite one, pending on month and year of the build as they are different. Manual gear surround: No longer available. Dual Zone ICC Cover: Can only get Dark Stone colour. Not the silver GT ones had either a clock or gauges, dont think you get them silver in a plain cover. If its an option, you get one of the above and paint to suit if need be? GT |
#418 | ||
Thanks for the detailed response.
It may be my only option going forward but I suppose I could just paint my current ones as they have some scratches only. I will have a think about it GT! Thanks! Sent from my iPhone using Tapatalk
#419 | ||
If GT cant help, try ASL Automedia in Melbourne. They are often selling various types of ICC fascia's on their site. Sometimes you need to call them to see what stock they have.
I had a mint FPV silver one earlier this year. Gone now though. |
#420 | ||
0o\==^==/o0
![]() Join Date: Oct 2008
Hi GT, I am after a Sx, Sy Territory rear tailgate garnish, the part that attaches to the lower part of the glass. Can you advise availability and price delivered to Brisbane.
Thank you.
Honorary Tony Oldest to youngest 1971 ZD Fairlane 1978 W123 Mercedes Benz 280e 2004 BA XR8 2007 W211 E63 ////AMG 2008 Fiat Ritmo -for the kids to take ownership of while I pay for running costs 2009 SYii Territory Ts 2011 W212 Mercedes Benz E350 returned to the kid but now bent. |
