Old 25-10-2021, 10:55 AM   #1
93Festiva
Default Australian spec instrument cluster into Canadian Festiva
Hello fellow members. I own a 1993 Ford Festiva 2-door hatchback with a 5-speed manual transmission. For some time now I have wanted a Ford instrument cluster with a stock tachometer, which was not a factory option in Canada. It was available as an option in the USA, but the speedo was in MPH and not KPH. I finally discovered that an Australian cluster has a stock tachometer and a KPH speedo, but the wiring harness for the Australian Festiva cluster is pinned differently than the Canadian harness. I have managed to figure some of the wiring out, and verified that there is a factory tach wire run from the coil to the cluster. Would anyone happen to have access to a wiring diagram for the cluster in an Australian Festiva that they could share? I would really appreciate any help that anyone can offer. Thanks in advance!
93Festiva is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2021, 12:36 PM   #2
GTLEGEND
Default Re: Australian spec instrument cluster into Canadian Festiva
1993 is change over year for Festiva, do you have a WA or WB Festiva as they are an entirely different shape?
Old 25-10-2021, 01:57 PM   #3
93Festiva
Hi GTLEGEND. My Festiva is a WA body style. Thanks for your response.
Old 25-10-2021, 03:09 PM   #4
GTLEGEND
Is this what you are after? Its one page but I had to cut it into 4 sections as it was too big to attach as one.
Old 25-10-2021, 05:08 PM   #5
93Festiva
Hi GTLEGEND,
Thanks for the diagrams that you sent. They were exactly what I was looking for. I'll let you know how it turns out once I repin the cluster harness plugs and install the cluster. Thanks a lot for your help!
Old 26-10-2021, 10:39 AM   #6
93Festiva
Originally Posted by 93Festiva View Post
Hi GTLEGEND,
Thanks again GTLEGEND! Those wiring diagrams showed us exactly how to repin our cluster harness for the Australian cluster. It worked right away with no issues except for a couple of burnt out dash bulbs which are no big deal to change. What are the chances that you would have access to a wiring diagram for the wiper and turn signal switches? We're also swapping in Australian versions of those to get the option of intermittent wipers which wasn't an option in Canada either.
Old 26-10-2021, 05:23 PM   #7
GTLEGEND
Is this what your chasing? I had to split the page into 3 again as one page was too big for here!! This is wipers..
Old 26-10-2021, 05:28 PM   #8
GTLEGEND
Head lights:
Old 26-10-2021, 05:32 PM   #9
GTLEGEND
Wipers, sorry first one is blinkers:
Old 03-11-2021, 03:51 AM   #10
93Festiva
Thanks again GTLEGEND! I'll give that a try but it looks like exactly what I'm looking for. Thanks again!
Old 13-11-2021, 12:58 PM   #11
93Festiva
Does anyone know what this lever is for on the back of a WA Festiva speedometer? It can move into three different positions and I'm not sure which one it should be set at. My speedometer id currently out roughly 12 km/h at about 50 km/h when comparing to a GPS speedometer. I am currently running the stock 12" tire size. Thanks everyone.
