17-11-2021, 08:02 PM | #1 | ||
Hi,
would an auto from an EL falcon, part number 94 DA 7000 BB, fit an AU Falcon 6 cylinder. Are the bellhousings the same? Any help would be much appreciated.
Fords I own or have owned: XW UTE, XW FAIRMONT, XT GT, XT Fairmont, EF XR8, XH XR8 UTE, XH XR8 UTE, AU UTE, Renault Scenic, XF UTE, BA XR8 UTE, TERRITORY, Chrysler Voyager, WS FIESTA ZETEC,TERRITORY TITANIUM, BA UTE, Nissan Pathfinder, AU Falcon Forte, BA XR8 UTE. |
17-11-2021, 08:50 PM | #2 | ||
i put a ba 4 spd 6 cylinder auto in my el
unbolt bolt up connect wiring and drove some say the ba had different internal solenoids but it seemed to run alright to me the ef el and au i hear are meant to be the same but the ef has the dipstick (i think) and the el is meant to be the stronger box from what ive heard but otherwise all are same same box
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
17-11-2021, 09:41 PM | #3 | |||
Only major difference is the removal of the dipstick in the 96DA box. But yes they otherwise fit, bolt up and work fine. Its been done many times before. No. The 6 main top bolts are identical, but the lower bolts are different. EL bottom bolts are connected to 2 alloy brackets that are bolted to the side of the block and are in a different spot. AU sump is cast to specifically match bolt pattern on an AU box. But you can slide the converter off and swap the bellhousing if you want and makes you more comfortable. Otherwise people have successfully used E-series housing to AU block before. |
2 users like this post: |
17-11-2021, 10:01 PM | #4 | ||
Thank you very much for the info.
Mods, kick this back to the driveline threads.
