Walking with God
I called Hightek Brakes for dba slotted and Advance pads.
Answer is great news for us all! $100 each front or rear, $55 for advance pads $10 postage to Melbourne metro area. Even better news, this price for AU's is permanent until dba put up their price. ![]() ![]() ![]() GK
#2 | |||
Removed by laminge |
#3 | |||
Walking with God
GK
#4 | |||
#5 | |||
Walking with God
GK
#6 | |||
![]() Join Date: Jan 2005
#7 | ||||
AFF's 1st DM.......
#8 | |||
This is true, I forgot to mention it because it's (to me) common sense. Well worth mentioning though. I still believe the AU1 brakes are more of a pain to work on than the previous models, I had no such dramas (air in the lines) with my EF or EA or XF before it. Still gotsta do the braided lines yet.
Walking with God
Thanks for that info fellas. I'll buy a couple of bottles of Shell fluid tomorrow.
Any special technique apart from smooth pedal pushing and the one way valved bleeding tool? Any special tools required to push the piston back? Any ABS issues I should be aware of? Come to think of it, I have a brake spoon (unopened) in the shed! LOL! Time to put it to some good use! I'm changing pads on rear, and rotors and pads on the front. Rough time estimate? GK
Walking with God
Bump!
#12 | ||||
AFF's 1st DM.......
Use a pin punch and whack the countersunk screw that located the disc as sometimes they are stiff and youll end up buggering it trying to undo it. Rough estimate. taking it steadily rears say1 hr. As for the front im not sure, for me to jack , remove wheels,remove calipers,grease bearings,etc etc steady pace no rush 40mins each side... just be aware when pushing the pistons back in, make sure the brake fluid level is very low otherwise you'll end up with fluid goin everywhere
#13 | ||
Pretty much what SVO347 said, except rear pistons on AUs are not the screw type as found on the early E series (thank God). I use a G clamp (and a small block of wood - 1 1/2" wide by 1/2" to 3/4" thick & 6" long) to push the piston back on both front and rear. No bearings to worry about with the fronts. And the countersunk screw can be a real b!tch to undo.
All up, not including flush, I can do the lot in about 1 hour. First time I did it though, it was more like 3 hours (Remember that Mr Cube??? LOL) just for the bloody rears. Add an extra 40 mins or so for a complete flush.
#14 | ||
Walking with God
Thanks guys, I've added that info to my file.
GK
#15 | |||
Walking with God
![]() Otherwise I would probably use 2 stands, and do the rears first, considering that's where I need to start with the bleeding and flush process. What do you think? GK
#16 | ||
Personally, I would not trust 4 jack stands.
I would (and do) start with LR, change discs, pads and bleed. Then do RR and keep going around the car doing RF last. That way you only need to take each wheel off once. JC
#17 | ||
Walking with God
Thanks for that advice!
GK
