08-10-2022, 02:03 PM | #1 | ||
My power steering pump chewed itself up, along with tensioners pulleys and belt.
I can get a 6pk 2515 belt which every one seems to agree is the correct one, but it's a very tight fit, and I will have to use some force to make it fit.There is a 6pk 2530 available, meant for a Mercedes (says Repco). Is the 2515 the go or the 2530. Seems a lot of us have the same trouble, so I'm looking for something concrete to go on, Repco is next to useless on this. Thanks in advance. Bobc. |
08-10-2022, 03:39 PM | #2 | ||
08-10-2022, 03:44 PM | #3 | ||
Run a straight edge across the front of the pulleys to make sure they are running straight if a pulley, idler or pump is on the **** a bit it'll chew stuff up can make em squeal as well if you can get it on its not too tight best of luck
08-10-2022, 05:44 PM | #4 | ||
I should have thought of that, will check it straight away. The drive belt will go on with force, but I didn't want to be to heavy handed with it. I Have probably read to much and got myself confused (again). Will get onto it again tomorrow. Thanks for your advice , cheers, Bobc
11-10-2022, 05:52 PM | #5 | ||
Check your parts numbers, http://www.fordforums.com.au/showthread.php?p=5303319
23-10-2022, 12:49 PM | #6 | ||
Gates AU 6 cylinder Serpentine belt part numbers.
Ford number AJK6995 (NON VCT) Ford number AJK6956 (Fits VCT)
