This piece fell off when someone took my door trim off. He has no idea what it is or where it came from. I've taken the door trim off many times, and have never noticed it before. I took the passenger side off and can't see a matching piece, which leads me to think it might be something to do with the driver side door lock nozzle, but its not obvious where it goes.
Everything seems to function fine without it. Anyone got any ideas? ![]()
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. ![]() |
#2 | |||
Regular...with metamusal
![]() Join Date: Oct 2009
think it's to do with what you mentioned as a security cover [?] for that. will try tomorrow for a pic to show where it goes. cheers |
![]() Join Date: Dec 2006
Yeah to stop someone picking the key lock from above between the glass.
Hey mad, any chance you can get a pick over the next day or so? Keen to put it all back together. Had a quick look at the WSM and can't see anything like that piece in the diagrams. Thanks a million!
#5 | |||
yep - sorry your msg reminded me ![]() ![]() ![]() hope that helps you out. as too window switch .. could be old age, unplugged motor etc etc.... |
#6 | |||
As for the window switch, its fried. $15 ebay cheapy on its way :P ![]()
#7 | |||
your welcome. going by the pic of your switch .. it's been doing a lot of arking, did it struggle with the glass at times?. |
Yeh, for the last 2 or 3 years lol. Had to keep cleaning and lubing the seals. Only recently discovered that selleys stuff which seems to last longer. Oh and had to replace the outer weather strip too.
Is there a trick to removing this bolt? It won't come out, came out 3/4 then keeps spinning.
#10 | |||
door handles foorked.... ![]() ![]() that's the goood news ......... ![]() possibly have to remove the door handle totally as the nut is loose in the plastic .. from memory. |
Yeh the guy has put the wrong bolt on there. Bloody hell. In your pick the bolt is a lighter colour, and that bolt is sitting in my cup holder. Ffs. Freaken annoyed.
#12 | |||
yeah it's def lighter .... and longer lol as it should be sitting in your door ![]() with bolt & cover removed ![]() the cover sits like so up top ![]() but is actually sitting over ![]() that plastic 'bit' so it's locked in. so it's either cut or drill that bolt out . . . . i believe?. |
#13 | ||
Good to know the threads are metal and not plastic. Will get my mech to retap it when I drop the car in next. He is an expert at retaping all the threads I've stripped in the past
#14 | ||
#15 | ||
I had the same problem, I heated up the bolt to melt the plastic that holds the nut then it just pulls out.
#16 | ||
Ah crap. So the metal part is spinning against the plastic? That's going to make getting it out a bitch. Think easiest is to saw the bolt head off and somehow pull out through.
#17 | ||
#18 | ||
I'd imagine so. If the bolt is stuck in the nut, then you won't be able to pull it out through the inside because it goes through a metal frame which is the size of the bolt threads?
Dunno, let the mech work it out lol. Or tempted just to leave it be. ![]()
#19 | |||
possibly best to either leave it or drill the bolt head using a drill bit just a little bigger than the threaded part of the bolt so it breaks off?. use a spanner etc to hold the bolt steady whilst drilling.. cutting it could cut .... anything ![]() Ps. but you will have to 'chock' that bolt so it don't rattle if you leave it alone. Last edited by mad2; 30-07-2023 at 09:59 PM. |
#20 | ||
Took another look, wouldn't be hard for someone with an electric saw to saw it off, because I did manage to get about 1/4 out (yeh I know I said 3/4 below :P).
Don't think you can get a drill to line up with that bolt, the metal frame is in the way. Anyhow, its not rattling or loose and the handle is firm, so I'll worry about it later ![]() Door trim back on, put some new tabs in there, and its now solid as a rock. Those tabs are like gold...$4 each!
