28-04-2006, 09:01 AM | #1 | ||
Fantastic Plastic
Hi guys , bit of a problem i have and am hoping someone might be able to lead me on the right track to adjusting some settings or something .
Anyway, the topic is the kickback of gears in the auto when you put your foot into it. For some time now i had been driving around on setting 3 ( adaptive shift ) and found that the auto responds straight away when kicking back a gear when putting ya foot down ( all fine in setting 3 ). But - Recentlly i started using setting 1 ( Power setting ) which i prefer in the way of it revs out to higher rpm before changing, but the problem is when im cruising then i when i put my foot down the auto takes about a second or so before it decides to kickback a gear ! , any ideas anyone on what might be wrong or how to adjust the auto or some settings or whatever so it will kick back straight away in 'power mode' setting 1 ?? , or is this pretty much how the auto responds in setting 1 from factory? any help would be greatlly appreciated , thanks .
------------------------------------------------------------ :eclipsee_ |
28-04-2006, 09:15 AM | #2 | ||
Smile
My auto non xr6 ecu seems to respond with the lag many times and many times not.I notice with the shift kit on it tends to be alot better. It may be a reduction in line pressure but I am not certain.
28-04-2006, 09:21 AM | #3 | ||
Fantastic Plastic
Just has me wondering , cos' on adaptive shift it kicks back straight away. I'de be interested if it's line pressure because i though that only effected the smoothness of the shift/how hard it shifts. Just after working with trannys years ago they either used a bar or a cable joined to the carby and settings were made from there ( and there was only 1 setting too ! ), but his being a newer auto , with 3 settings , and 1 setting works fine and the other doesn't makes me wonder what the hell it is ..lol .. cheers .. more suggestions welcome plz .
28-04-2006, 06:03 PM | #4 | ||
My XR8 does the same but it also does it in economy mode as well as power mode unfortunately i dont know why just letting you know that it might be a common thing.
My Ride
2005 BA MKII F6 Typhoon- details soon. |
28-04-2006, 08:00 PM | #5 | ||
if it bothers you guys so much you could also manually downshift too. i do this sometimes as it is instant and after downshifting you can tramp the pedal good.
but have you guys tried resetting the ECU to see if that helps or makes any difference. because the ECU learns how you drive and adapts the shifts accordingly.
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
28-04-2006, 09:03 PM | #6 | |||
29-04-2006, 02:13 PM | #7 | |||
Fantastic Plastic
I think your onto something there mate ;) , cos i have also noticed now that if i tramp it around for a while in econ or power mode then it seems to kickback fine again after driving like a hoon for a while , just strange how it kicked back no problems straight off in adaptive shift mode - then again - it had probably allready learned my driving style in adaptive shift as i used that most of the time for a long time before . cheers .
29-04-2006, 03:12 PM | #8 | ||
Get the edit... 100% preprogrammed "hoon style" ECU 100% of the time :
29-04-2006, 03:57 PM | #9 | |||
Fantastic Plastic
that sounds like the go .
29-04-2006, 04:32 PM | #10 | ||||
AU DIE HARD
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... .................................................. Quote:
30-04-2006, 01:51 AM | #11 | |||
Miami Pilot
My XR8 has been doing some dogdy things lately too - like when I tramp it while moving (eg at 60 or so), it does not kick back straight away, but when it does, it kicks back, and then half a second later kicks back again (so goes from D to 2). However, the next time I try the same thing, it's fine - one kickback to second, instead of 2 kickbacks to get to the same gear. I think a lot of it has to do with temperature of the box, outside temp etc - I find that my car usually runs heaps better on mild to cool days (lucky I live in canberra, hey?).
30-04-2006, 03:07 AM | #12 | |||
Fantastic Plastic
