29-07-2006, 01:27 PM | #1 | ||
Slide Baby Slide
Just trying to get some idea's on gauge setup's for my car. I wanna keep everything out of sight, well as out of sight as i can get.
Just trying to get some ideas. So post up your thoughts and pics. I've got - 1 Autometer 5" monster Tacho and shift light - 1 Water temp gauge - 1 Oil Pressure gauge I'm trying to find where to mount them without them sticking out. At this stage i was thinking about mounting the gauges on top of the dash in the middle (so in line with where the headunit is, just on top), mounting the tacho on the Door so when the door is closed it's inline with the air vent under where the switch for the headlights is and mounting the shift light where the dash and A-pillar meet
:the_finge You want more inches...........STROKE IT!!! :the_finge Mr Super Skid-Man |
29-07-2006, 03:22 PM | #2 | ||
The Vengeful One
I mounted my 3,3/4inch tacho on the top of my dash next to the front pillar, all you can see from the windscreen is its silver ***, doesnt stick out much really.
29-07-2006, 03:39 PM | #3 | ||
Slide Baby Slide
Got a pic?
30-07-2006, 01:57 PM | #4 | ||
Formerly GTP075
heres my setup
13 PX WILDTRAK brand new wheels and tyres for sale Pm me |
30-07-2006, 06:32 PM | #5 | |||
The Vengeful One
30-07-2006, 07:59 PM | #6 | ||
mount the monstah tacho on your rear parcel shelf, then everyone behind you can see what rpm you are doing. Also rig it up soo 5500 rpm reads 11,000 rpm on the gauge, cause that would be cool.
31-07-2006, 01:58 AM | #7 | ||
Oops, I slipped....
I'd cut the clear plastic out in front of the original tacho and mount the monster tacho in there. There's a few spots to mount the other gauges in the centre part of the dash, either above or below the head unit.
Something to keep in mind, it's an instant Regency Park roadworthy if the Police defect you for gauges mounted on top of the dash. :(
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
31-07-2006, 02:13 AM | #8 | ||
[ 5L ]
and you dont want to go to regency, coz your more likely to go there 2 or 3 times before it gets off
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
31-07-2006, 02:36 PM | #9 | ||
i've got a 3 3/4 shift light tacho on the a pillar, its barely visible from a distance. also have water temp and oil pres. but only hooked up the lights atm. apparently oil pressure will work, but consider the dash one gone, but the water temp wont work unless u get some aftermarket thermos, coz they are run using the temp switch for the factory gauge. i've mounted those gauge just in front of the T-bar, under the ash tray.
31-07-2006, 09:19 PM | #10 | |||
Slide Baby Slide
Was thinking about doing that with the plastic tho. I was out and about on Friday and saturday night, went past heaps of cops and all they did was look at me
01-08-2006, 04:44 PM | #11 | ||
Pods rule
Put the tacho on the passender side of the dash above the grove box where they now put airbags
EB xr6... Now sold : Check out Build- http://www.fordforums.com.au/showthread.php?p=3083422&posted=1#post3083422 Current Rides- Xf ute, just installed ea wiring loom, dashboard, 3.9lt mpfi and a 5 speed with extractors and a 2/1-2 exhaust... its much better now! Check out Build- http://www.fordforums.com.au/showthread.php?t=11288204 -BF XR6... And its BLACK! |
01-08-2006, 09:31 PM | #12 | ||
i,ve installed tacho,lpg fuel guage, oil pressure & water temp guages (all spec thomas silver except the lpg guage) into my cluster (cut the holes into the original guage facias)and have retained the original speedo. It's certainly different.
project #1: Ea series1 Spac conversion to straight gas; 351Cleveland; T5; EB dash; sunroof and more as I get to them. :evilsasmo Fully road legal and cruising in QLD!! --------------------------------------------------- Happy dealings with; PROTD, !gn!t!on, Big_waity,Phongus |
01-08-2006, 09:34 PM | #13 | |||
Slide Baby Slide
01-08-2006, 09:39 PM | #14 | |||
V8 Turbo Hoon
the e series fords have one of the best dash layouts for tacho, oil pressure speedo etc, why make it look worse with these add on's i say put the money towards fining the missing power from your 347 : |
01-08-2006, 09:52 PM | #15 | |||
I've got the same problem as you. The only decent tacho I have in the shed is a 5 inch white face tacho and I don't want to mount it on the dash as the car is to be a sleeper. I'll probably see if I can mount it behind the steering wheel on the left or if there's no room I'll move it down a little and mount it off the side of the console. I'm only using it for the shift light and its bright enough for me to see out of the corner of my eye even when mounted down low. |
02-08-2006, 08:27 AM | #16 | ||
a work in progress
02-08-2006, 08:41 AM | #17 | ||
Ditch the monster tacho and mount the other 2 on the A pillar or below the CD player in that small space or where the clock is at the top.
You have a tacho dash anyway yeah?
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
02-08-2006, 09:19 AM | #18 | ||
This is my setup. Don't strictly need the oil pressure gauge but I don't trust the Ford one. The advantage of having them on the pillar is that they are at eye level. I believe it outweighs the disadvantages.
Will all have to change when I put a cage in it anyways... |
02-08-2006, 09:32 AM | #19 | ||
Slide Baby Slide
Thinking about the A-pillar for the two small gauges. With the tacho i'm thinking about cutting the plastic over the original cluster and sliding the tacho in there then placing the shift light somewhere else. I'm gonna get mock it up in the next few days, i have a few ideas now
02-08-2006, 10:57 PM | #20 | ||
Slide Baby Slide
I wa thinking with the setup i'm planning. Eventually, i want a complete sutom dash cluster with all after-market gauges....but thats a bit down the track
03-08-2006, 11:34 AM | #21 | |||
Wherever u go there u r
03-08-2006, 11:35 AM | #22 | |||
