07-10-2006, 06:10 PM | #1 | ||
Hello people.
I'm wondering if anyone has had troulble with the passenger side boot hinge lever on their fairlane? Is there some sort of bush assembly? I know you have to remove the inside moulding to get to the bolt to tightened it up. It seems like it works its way loose and then my boot is out of wack and wont close. Is this a common problem?
www.theretrofitsource.com |
07-10-2006, 11:53 PM | #2 | ||
Flat floor shifter
No troubles with mine and it's opened and slammed shut about 10 times a day.
08-10-2006, 12:13 AM | #3 | ||
Fantastic Plastic
Put some locktight on the nuts next time you tighten them , or use another nut behind the original and tighten the second nut hard into the original tightened nut / cheers.
08-10-2006, 09:11 AM | #4 | ||
thanks guys..
