#1 | |||
Found a privately imported Mondeo for sale on the Trading Post website today- for only $82,000!!!
![]() I can't post a direct link to it, but it's a '97 Ghia hatchback (ie not the latest model sold overseas; similar to what we got HD/HE shape) with sunroof, 2.5l V6 engine (same as my ST24) and it's covered 130,000km!!! I'm hoping it's a mistake - surely they can't be serious? ![]() Here's a cut and paste: Quote:
2016 Kuga Titanium 2.0l EcoBoost |
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
damn....
are st24's 5 or 6 speeds?
AU - YEA YOU!
prolly got an extra 0 in the price (so real price more like 8,200?). see that in the trading post form time to time
AU II XR6 VCT - JMM DEV3+
ST24's are five speed (unless you include reverse?
![]() The advert is repeated twice- one with pic and one without. Guess they could have stuffed up the price twice?
not here much anymore
Would have to be a typo - 8200 for sure.
RAM 1500
Zoom Zoom
what's a regular 97 go for?
2012 Mazda3 MPS
windsor user
perhaps he's trying to recoup import and compliance costs lol.......
Supes
should call him up just to let him know he is dreaming
Yes I DO drive a Toyota |
Heres one othe the other end of the scale...
A Mondeo ST24 for 10K http://www.drive.com.au/used_cars/fo...pp=11&d=0&nv=1 |
Virtuous Bogan (TM)
ah I want to see pics! The page seems to be down
that woudl have to be the cheapest st24 in the country....wonder whats wrong with it?
The only ST24 I could find on that site has $20990 and 62500km..... Makes mine look like a bargain!?
#12 | ||
Virtuous Bogan (TM)
please dont make me look at your car anymore, I nearly cry everytime. If I wasn't saving up to go OS then that car would be mine
![]() Just to drop a bombshell ive driven a new ST220, holy crap that thing rocks, and the st24 is the same breed so it cant be too far off.
Only 50hp off ;)
#14 | ||
$82000 mondeo. that would be a Jaguar x type wouldnt it?
#15 | ||||
#16 | ||
I took a look at this car the other day. It is in fact $7,500 now. Didn't like it because the engine kept revving when my foot was off the accelerator and it felt like it it was driving itself. All in all an unpleasant drive in my opinion. Also the V6 is NOTHING to get excited about at all. It is a very boring engine.
#17 | ||
Zoom Zoom
Yep, they all do that.
2012 Mazda3 MPS
#18 | ||
You can fix the revving by putting a restrictor in the IAC valve line. Did it to mine and it was so much nicer to drive.
![]() Mine went quite well, quicker than V6 Commondoors from the lights and excellent for overtaking in the country without changing down gears. The engine was the best part about my ST24. I did have a pod filter fitted, which I took off just before selling and it did feel like it had less power. BTW Motor (or Wheels?) managed a 15.7 second 1/4 mile when they were first released from a stocker. Perhaps that one is shagged?
2016 Kuga Titanium 2.0l EcoBoost Last edited by murcod; 02-07-2005 at 11:16 PM. |
#19 | ||
Zoom Zoom
Hmm interesting. I might just try that, bloody ICV... cars know too much for their own good IMO.
2012 Mazda3 MPS
#20 | ||
It takes a bit of experimenting to get right, but basically find some sort of metal plug that will fit snugly into the IAC / ICV pipe that bypasses the throttle body. Make sure that if it somes loose there's no way it can get into the inlet manifold!!
![]() Before fitting it, drill a small hole in the middle (try 4mm first.) The idea is you're restricting the maximum amount of air that the IAC can bypass. After fitting it reset the ECU by disconnecting the battery (or pull the relevant fuses for the ECU.) Then try starting the car. You may find it takes a second try to start it, as the ECU needs to relearn the new settings for the IAC. Don't use the accelerator to help it start or the ECU won't learn the settings!! If you can't get it running after the fourth try, then enlarge the hole using the next largest drill bit (0.5mm steps are good) and try it all again until it will start on the second go without helping using the accelerator. Once it's started and idling smoothly turn on all the electrics you can think of (headlights on high beam, A/C, heater fan on full etc etc) and see if it can maintain the idle speed. If it can, you've got a good hole size; if the idle drops and it struggles then you need a bigger hole. You'll need to drive it around for a couple of weeks for it to relearn the settings for different temperatures. Providing it starts second try then the ECU shouldn't have problems again with those same conditions. Before the mod my Mondeo would accelerate down hill after I'd backed off in fifth gear; and the revs would hang around 2000rpm as I changed gears. :( It was a lot easier to drive afterwards, and also didn't rev it's ring off when first started cold (ie. would have to help with longterm engine life.)
#21 | ||
Zoom Zoom
David,
Thanks for that post, very informative and really helpful. I'll wait till my mate here at Ford has a go, but then will certainly give this a try if I still have the problem. Just some questions, why does it need to be taught correctly when it should bloody work in the first place?!!! Do you think it's a bit of a hoon guard, that it basically only happens in cars driven hard and then reacts accordingly? Shouldn't be... but would geting the ICV replaced have it's original effect? Sounds in all honestly like it's due to a high-flow filter. I have a K&N panel filter.... more air in = more air past ICV = confusion, but why the hell can't it still use it's brain and look at the Throttle Position Sensor to realise you've backed off?!?!?!! Has frustrated me for the best part of a year. It's the ONLY single fault with my otherwise perfect car than just makes me smile. I get all the high revving on startup, hanging on clutch-in, coasting down hills, even a cruise-control efect on the flat straights. Personally it's not safe and it also makes me use my brakes more often, I already replaced the front discs and full pads at 48,000km after one disc nearly wore through and started ripping up my front left brake pad unevenly. Thanks again mate!
2012 Mazda3 MPS
#22 | |||
#23 | |||
That's my understanding of how it operates anyway! (In my experience the ST24 would start second go (after having the battery disconnected) and after a week it was happy. The new owner has been complaining about starting problems- but she has been using the accelerator to help it start ![]() When you back off the accelerator suddenly the throttle almost instantly closes; the IAC valve staying open helps to reduce emissions by ensuring the mixtures don't spike rich when it happens (from traces of unburnt fuel exiting the exhaust.) Same disclaimer as above- my understanding of it only. ;)
#24 | ||
Zoom Zoom
Yeah it's the software that makes the throttle stay open that stuffs it all up, means it can then stick open a little, bloody low technology eninges. That's what you get by putting a decade old engine into a modern car. Only thing I hate about the Zetec is it's stock tune. But DAMN is it a moddable engine!!
2012 Mazda3 MPS
#25 | ||
G, I thought it was strange importing a V6 from the UK, but check out this 1995 Estate: http://cgi.ebay.com.au/ws/eBayISAPI....tem=4560291426 What a bizarre car to privately import.
#26 | ||
Zoom Zoom
I think you'll find it was sold in Oz, just a definition "import" for some bogan Queenslander who know nuthin but Falcodores, notice the "not Falcon" in the title LOL. Had to be the Gold Coast... the America of the North... the home of Big Brother...
Queensland Dictionary of Engwish: Import (eem pawt) - something other than XXXX You'll also see it's a 2 litre Zetec (not VTEC like the sorry ****er says.) There's one born every minute. 10 bucks says he wants a Camry Sportivo next...
2012 Mazda3 MPS
#27 | ||
Clio 182 CUP!
LOL! "Sporty Roof Racks"... how so?!
Also, laughing at the negative comment he has from a buyer! :evil_laug
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) |
#28 | ||
Good luck selling that one! ROTFL
260000km, an import 2l LX (bottom of the range IIRC) and a starting price of $5000!
