View Poll Results: whats worse for a cold engine? | |||
load | 29 | 16.11% | |
rpm | 65 | 36.11% | |
both are equally as bad | 86 | 47.78% | |
Voters: 180. You may not vote on this poll |
08-11-2007, 12:05 PM | #1 | ||
13.96 @ 101.65
well, do people think that revs or load is worse for a cold engine. just interested as i have to pull onto a highway before my engine is at normal operating temp
cheers
BLUEPRINT XR6T XR8 CAI - K&N Filter - T56 - Generic Tune
08-11-2007, 12:35 PM | #2 | ||
LPG > You
Both. I never move my car until the temp gauge jumps a bit off stone cold. And even then, its nice and slow until everything gets normal. 2-3 min of sitting there in the morning doesn't bother me.
LPG Lovers Association President & Member #1. : |
08-11-2007, 01:11 PM | #3 | ||
Complete ****** n bogan
According to the SMH it is actually bad to leave your car idleing when you are trying to warm it up because aparently it produces more carbon on your cyclinder heads.
When I warm it up, I just go about 1200-1300 RPM. |
08-11-2007, 01:37 PM | #4 | ||
Load: Bad because applying higher cylinder pressures to a cold engine will result in more blow-by and increases the possibility of gases creeping past the head gasket, causing it to fail. Older english cars are notorious for blowing head gaskets with even a slight thrash when they're cold. As the engine warms up, the pistons expand as does the block and head, which reduces the clearance around the piston and increases the clamping force on the head (dependant on materials- an all iron engine may actually lose clamping force due to the lower coefficient of expansion of irons compared to high tensile steels.)
RPM: Bad because the oil is not warm and so is still thick. Giving an engine high revs when it's cold will greatly increase the stress on the oil pump gears and drive, possibly causing premature failure. If the the oil can flow into the pump sufficiently at that temperature, the high oil pressure created may blow out seals etc (again thinking about clamping forces) but if it can't suck the oil it wants, it may cavitate, causing pump damage and possibly causing starvation at the bearings. Another thing is how long it takes to run back to the sump- if all the oil is up the top, then say goodbye to bottom end bearings. The thicker oil generally puts more stress on all engine components as it takes more torque or force to move them. Also, oil consumption is not helped either as the thick oil is more likely to stick to the bores as the scraper ring comes past. This plus greater cold clearances is why you get blue (oil) smoke when you give it to a cold engine. |
08-11-2007, 01:44 PM | #5 | ||
One more thing- High RPM is also bad when cold due to higher clearances. Bigger clearances mean more freedom and so more chance of scuffing, flogging out holes/slots, etc.
08-11-2007, 02:52 PM | #6 | ||
the whole warming car up thing has been done on here plenty.....
08-11-2007, 03:11 PM | #7 | ||
i just drive normally
by the time any damage is done some other sucker will own it lolz |
08-11-2007, 04:13 PM | #8 | |||
LPG > You
08-11-2007, 04:21 PM | #9 | |||
IWCMOGTVM Club Supporter
Also according to the cars manual, that you shouldn't let your car idle to long. New cars are designed to be driven from cold, so if you dont thrash it nothing bad will happen. |
08-11-2007, 04:38 PM | #10 | |||
Its Resonating!
08-11-2007, 07:23 PM | #11 | ||
I knew a guy who has a VN SS and it would see 4000+ RPM daily within 30 sec's of start up and it still doesn't show any signs of something failing.
With todays thinner oils there would be less instance of oil pump stress, modern metal technologies and tighter engine tolerances also take care of the engine wear, potentially there would be no noticeable issues showing up if you like to flog a cold engine. Don't take this as something I support, I'm on the fence here, technology changes quickly. |
08-11-2007, 08:02 PM | #12 | ||
Not suprised English cars are crap The trick is to warm the engine as quick as possible eg.no prolonged periods of idling and no caining it either just drive "normal" thats all u need to do and yes leave the thermostat in
XR6 BF 2006, 6 SPEED AUTO LIGHTENING STRIKE SILVER F6 INTAKE, PREMIUM SOUND FULL ELECTRICS . RUNS ON RAILS !!! : |
08-11-2007, 09:56 PM | #13 | ||
Peter Car
I used to work with this guy who claimed that fuel injected cars were great because, I quote, "you can just start them up and thrash them straight away, you don't even need to warm them up". But I guess he drove a VN Aero so that sort of makes sense. :
08-11-2007, 10:43 PM | #14 | ||
All this "new engine" stuff is crap, metal is still metal and oil is still oil. Yes they are better designed and cope with a wider range of operating temperatures, but that doesn't exclude simple physics.
09-11-2007, 02:19 AM | #15 | |||
09-11-2007, 01:42 PM | #16 | ||
And whats the go with forged pistons in this respect? i was told to warm it up fully.....
09-11-2007, 03:27 PM | #17 | |||
VFII SS UTE
simply short shift the gear's at quarter thottle until warm
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
09-11-2007, 05:02 PM | #18 | ||
White Car Driver
Well I don't go to too much trouble, I'm not going to let it sit and idle for a minute just to "warm up", but at the same time I'm not going to bounce off the limiter up the hill. I just take it easy.
10-11-2007, 12:04 AM | #19 | ||
The absolute worst thing you can do to a cold engine is ...
turn on the ignition. Seriously leave off the ignition and then you get no wear at all. |
10-11-2007, 12:11 AM | #20 | ||
Performance moderator
The nut is the worst thing on an engine..
Excessive rpm as clearances are still loose etc.. Some slight load won't hurt as it helps engine warm MUCH quicker... I had a 3 series BMW and in its tech section it says to warm the engine As quick as possible with light load... But really if you have to ask?? I'm sure common sense prevails ???
10-11-2007, 12:16 AM | #21 | ||
Can't say with this car, I've really ever let it idle to warm up. I just short shift with as little boost as possible.
It's a bit hard to get reasonable speed from my car with out a decent amount of RPM. No problems so far! |
10-11-2007, 01:16 AM | #22 | |||
Anyway back on topic just drive the car normally, keeping the load light and revs low, for the first 15-20 mins (dont let it sit there idling for too long). |
10-11-2007, 01:29 AM | #23 | ||
I would LOVE an E type or a DB9 (or is that a vantage?).
The Range Rover.... Aids thank you. |
10-11-2007, 05:05 PM | #24 | ||||
LPG > You
No car is designed to be driven from cold. I'll quote a post I always do in threads like these, from the 'Warming GT,' thread in the FPV section of this forum from a while ago... snipping the bits that were irrelevant to the post (aimed at someone else in the paticular thread). Quote:
And the thread itself... http://www.fordforums.com.au/showthr...ght=warming+GT
10-11-2007, 06:11 PM | #25 | ||
DJR TM#54
I been told by a number of a few mechanics is that the best way to warn you car up is to start the car up & let it idle for about 30sec then drive off normal. This is what i've been doing for years & never had a problem with any of my cars.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went. Now Zetec Powered. 1.6lt of madness. But the XR8 still remains |
11-11-2007, 12:31 AM | #26 | |||
Something else worth considering- when combustion gases move past the piston and rings (when the car is cold or worn out) the oil deteriorates and loses its ability to effectively lubricate. Compounds may also develop which can attack some materials. This can be minimized by...minimizing cylinder pressures...ie load. It's also worth noting that combustion gases moving past piston rings and ring grooves are bound to leave deposits (though tiny) and over time these may build up and cause a ring to jam, which would cause some serious problems. It's fairly obvious both are a problem and combined they would serve to magnify each others negative effects... "more than the sum of its parts" or whatever. So be gentle... |
11-11-2007, 01:38 PM | #27 | |||
11-11-2007, 05:50 PM | #28 | |||
1 subject off being a mechanical engineer, with a huge bias towards automotive things. Just about aced the engine tech subject I took... |
11-11-2007, 06:34 PM | #29 | ||
All mechanical and electrical engineers should be made to do a trade prior to studying engineering.
11-11-2007, 07:27 PM | #30 | ||
I warm mine up for 5mins before driving off at around 1000-2000rpm
Simply because it won't idle when cold and will not move at low rpm's when cold.
TE cortina 14.0 @ 101mph E32 740iL Leather, sound system, rollin' on 19's |
